#51 |
Broke and still trying
Re: Show me your rims - 6 lug options
Those 15x14s are sweet! I have 15x10 Weld Typhoons on 35 Xterrain Pro-Comps on my k5 and 15x7 front/ 15x10 rear Corvette Rallys on the 68.
#52 |
[QUOTE=bigbadchev72;4823194]15x10 Corvette Ralleys
![]() Where are y'all getting these Corvette style center caps with the middles hollowed out for 4wd front hubs ? |
#53 |
People know me
[quote=viking427;4828223]You have to hollow them out yourself. Lots of patience and a dremel.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
#54 |
heres mines with centerline and mickey thompson baja claws ttcs 15x12 rims and the tires are 33x12.50x15s whats wierd about these rims ive seen rims like alcoas, michey thompson, eagle, american racing, center lines all look the same.
1972 gmc jimmy project comin soon ( jus a sin ) ![]() 1959 chevy apache shortbed fleetside (brsgrm) ![]() 1966 Chevy c30 duallie 2wd (big chief) ![]() |
#55 |
I have a 1972 Blazer that I would like to mount stock type steel wheels on. I believe the stock rims are 15 x 6, 6 lug. I would like to go to 15 x 8, 6 lug, to fill the wheel wells out a bit better. Does anyone know where I can purchase these? Thanks!!
#56 | |
Topic has surfaced before, check here; http://67-72chevytrucks.com/vboard/s...highlight=15x8 |
#57 |
Dig around enough and you'll turn up a set. I found some here local for mine. I decided to go the steel wheel route too, since aluminum wheel choices are drying up, most don't have the correct backspacing needed unless you want to spend $200 a wheel.
#58 | |
Recalculating.....
http://67-72chevytrucks.com/vboard/s...d.php?t=476651
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
#59 |
heres another shot of the rims i reacently aquired there 15x14s craggers i think i had some center line caps layin around i have them on for now but i was thinking of drilling and tapping and installing the rally caps what you all think...
#60 |
toys'r'us
do it but paint the center sectioin on the rim black and leave the rim polished. The flat color of the cap looks wrong on the shiny wheel. Painting the center section of the rim will break it up nicely
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
#61 |
Registered 1971 K5
I like them better with out the caps.
#62 |
Polished wheels look better with the chrome caps they were intended for, and they aren't that expensive. Install what's supposed to be on there and leave it be. Drilling any holes to mount different caps, or even painting the wheels, is going to make for a very tough sale if you ever want to get rid of them.
As far as painting the wheels black, you may as well buy a set of steel wagon wheels for that and keep those for your offroad setup. Leave the aluminum polished. |
