#26 |
Project92 SWB stepside
hOW ABOUT SOME PICS OF THE BOTTOM??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#27 |
aka Crusher, Crushergmc
I just set my motor in a 1.5" crossmember notch. It's a 454 w/HEI and I had to move it foward about .5" for the HEI and up 1" to clear the crossmember. I also had chevelle headers to contend with. Because of those I cut my firewall to allow for the passenger side to fit (needed about .25"). I might have been able to fit them, but I didn't like them that close. It won't be noticable when I'm done. I've got pics but they are too big even to email. I'll have to figure out that when I get home and post them. Good Luck.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
#28 |
Just wanted to keep this one near the top. When someone get's their steering rack installed ------- post some pics....
#29 |
Talked to JAMES at Turners place and they are finally sending my things back to me!! They have had them for a couple of months now and I am far behind!!
#30 |
Still waiting on my rack to be shipped out to me!
#31 |
Man I hate waiting for my parts so I know it's got to be killing you guys!
#32 |
Its like a BIG game all the manufacturers play with us. They have your parts ready to ship one day then you call back a week later and they say oh we are just finishing them up they should ship out friday!! It sucks!! Just be honest and tell me the truth.
#33 |
Finally got my crossmember back!! Here are a few pics. Bad thing is i found out that the odd brackets that you see in the pics laying under the member have to be added to the frame in the front to notch out for the rack and pinion. I already have my frame powder coated!!
#34 |
X member pics!!
#35 |
pic
#36 |
Nice! I am waiting on my rack still but got almost all myother parts. Do you have any other pics? top view and so on- Mine will be alittle different. I did a 2 inch notch in my crossmember. Oh man hope I get mine real quick here.
#37 |
Yes, more pics from different angles please. Also, what application is the rack originally for? Looks good, I bet you can't wait to get it installed.
As for your frame dilemma, that does suck. That's one reason I just coated mine w/DP black epoxy. It has been cut, drilled, & welded on several times after I was 'done'.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-11-2003 at 07:36 PM. |
#38 |
Rack is originally for a Mustang 74-78.
#39 |
Progress = 0%
Question: How are you going to get the steering shaft to hook up the the rack?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#40 |
![]() Join Date: Aug 2001
DOH! Surely if someone has designed this setup they have a solution for that too - 6 or 7 knuckle joints?
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
#41 |
I'm thinking probably 3 joints- but no telling till you get header and a block in there! I want to see more pics!
#42 |
www.loweredd.com
Does anyone know of a company that has these for 73-87?
#43 |
Turner Enterprise- also does 73-87! Give him a call. Be prepared he will talk your ear off!
#44 |
Lately Bill is not to be found over the phone. Maybe he lost his voice!! 2 joints will get it!! Maybe one more to smoke as I install it all!! JOKING!! ANY ONE ELSE WITH PICS FEEL FREE TO POST!!
#45 |
Is that a standard length rack and pinion? Can I go find that year Mustang and get the rack from it and install it? Details please. Thanks
#46 |
Yes it should be standard. Note that I was told there is a difference between the power rack and the manual rack. I have chose to run the manual rack to clean things up.
#47 |
www.loweredd.com
how easy will a manual rack steer on our trucks though? I had a Nissan pickup once with manual steering and it was a pain.
It probably wasnt rack and peanut steering though. |
#48 |
Once it gets going it should not be to bad.
#49 |
top view for whomever asked!
#50 | |
