Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-31-2011, 01:53 AM   #51
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: Ice cream getter
thats alot of wires
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 03-31-2011, 05:20 AM   #52
vtblazer
vtblazer's Avatar
Great to see this one making progress.
Body looks good!
vtblazer is offline   Reply With Quote
Old 08-16-2011, 10:10 PM   #53
SONOSADSACK
SONOSADSACK's Avatar
Another five months have clicked by with little to show but little is better than nothing right? Still mocking things up before another round of disassembly. Motor mounts are finished and after trying a couple sets of off the shelf headers and not being happy I had a pair custom made. It hurt a little, but I got just what I wanted.
SONOSADSACK is offline   Reply With Quote
Old 08-20-2011, 11:06 PM   #54
SONOSADSACK
A little more progress…
My original engine/front light harness was really shot so I made one good harness using three junk harnesses. Really easy after figuring out how to remove the blades without destroying them.
Also put the left fender back on to make sure the location I choose to mount the ECM would work. That went well so I couldn’t resist hanging the right side. That didn’t go so well. Not happy with the gap at all. Two steps forward, one step back!
I put the tires and wheels back on just because…
Old 08-20-2011, 11:12 PM   #55
VA72C10
VA72C10
VA72C10's Avatar
I know you're not happy with the gaps but it's looking good in pictures
Old 08-21-2011, 07:55 AM   #56
jaros44sr
jaros44sr's Avatar
^^^I agree, looks perfect from here, gaps can be worked on later bfore paint
Did you polish the slots
Looks like a quality build so far
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-26-2011, 09:20 PM   #57
SONOSADSACK
Thanks for the good words.
I agree, the gaps can always be adjusted after paint but I’m planning to build the truck, tear it all the way down, add paint and bolt it all back together without any surprises. That’s the plan anyway. I worked in a body shop about fifteen years ago and recently ran into a friend of mine who is still there. He doesn’t work in the shop anymore but offered to help me out. Good people. They allowed me to come in on a Saturday when the shop is closed and use one of the racks. Never burn bridges. My friend actually did all of the real work, I just did the grunt stuff. Anyway, we found three body mounts had settled or tipped down along with the frame rail turning outward. The worst was the main support under the driver’s feet which had dropped by about a ½” and the front right frame rail was down about ½”. We also pulled the right side of the cowl ahead about ¼”. All of this gave me the gaps around the right door that I was looking for without shims and with all hinges and fender slots being on center. Now, if after paint I still want to make some small adjustments, there is room.
After a few tugs and getting really close
Old 09-26-2011, 09:29 PM   #58
SONOSADSACK
jarros44sr I just seen your question about the slots. They are actually “new”. I found them on eBay. They are MT’s that were discontinued several years ago. Some guy in California had four 12” and one 10” and would not separate them. I keep checking every now and again to see if I can find anymore 10” to put another set together but no luck. If not it will make for a shiny hose hanger.
Old 09-22-2012, 09:31 PM   #59
SONOSADSACK
Fall is here so it’s time to get back at it. I removed the Skyjacker leafs and replaced them with a set from Deaver. Rears are basically a bolt in but because of the additional length the fronts required a little more effort.
Fronts - Skyjacker vs. Deaver
Rears - Skyjacker vs. Deaver
Old 09-22-2012, 09:59 PM   #60
SONOSADSACK
After another round of tear down I cut out a section of the fire wall and replaced it with the panel that came with a Vintage Air setup I picked up. I also had an opportunity to use a rotisserie. Not necessary but definitely makes things easier. I think this truck has had everything imaginable mounted under the dash at one time or another. Lots of holes to close up.
Kind of feels like I’m not getting anywhere…
Old 09-24-2012, 12:29 PM   #61
SamMargritz00
SamMargritz00's Avatar
reading this brings back old memories lol.
good progress!
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 10-12-2012, 09:45 PM   #62
SONOSADSACK
I wish I had a good comeback to that but I don’t so I’ll just keep sanding and sanding and sanding…
The tub should be ready for paint tomorrow and I still don’t know what color I'm going with.
Old 10-17-2012, 08:51 PM   #63
hilljob26
hilljob26's Avatar
looks amazing so far,,,cant wait to see some color
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 10-17-2012, 09:47 PM   #64
SONOSADSACK
Picking a color is absolutely killing me. I am “borrowing” space at a friend’s shop and have to spray this weekend. I still have no idea what color though!!
Old 10-17-2012, 10:40 PM   #65
hilljob26
hilljob26's Avatar
the color that it was looked good,,myself, i think im gonna do a 2 tone..me and my boy really like this one,only i might use a hugger orange,not sure
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 10-18-2012, 06:33 PM   #66
notsolo
notsolo's Avatar
I hope you get a color you like(love) the 1st time...I painted the fire wall Sunburst Orange Met and decided it was too dark...I wanted something really bright. I finally mixed my own, more lime than olive. This Blazer is amazing, BTW...Good luck.
notsolo is offline   Reply With Quote
Old 10-19-2012, 12:23 AM   #67
coggonobrien
I'll will try and remember to look up the paint code, but what I'm using is Allis Chalmers Persian 2, it's an eye popping color. Here's our most recent restoration. David
coggonobrien is offline   Reply With Quote
Old 10-21-2012, 09:29 AM   #68
SONOSADSACK
Hilljob – that two tone blazer has been one of my favorites as well.
Notsolo – I like it. Reminds me of a ’75 I had. I think it was called spring something or other. A friend now owns that truck and says he gets compliments on the color all the time.
Old 10-21-2012, 09:38 AM   #69
SONOSADSACK
Coggonobrien – I don’t farm but I really want to restore an old Case someday. I found a slide dated ’64 of a 530 that my wife’s grandfather owned and have wanted one ever since.
Old 10-21-2012, 09:51 AM   #70
SONOSADSACK
Well, after way too much thought I finally decided on a color. Dark olive it is. Not the direction I was originally thinking. I was looking for something bright and bold so I’m not sure so sure how I ended up with this. Should have had the outside completed too but had one of those nothing went right experiences.
Old 10-21-2012, 10:08 AM   #71
notsolo
notsolo's Avatar
Looks great...Dark Olive Excellent choice...This was in my top 10 file...not mine unfortunately...
Old 10-21-2012, 12:04 PM   #72
Gillnetter
Gillnetter's Avatar
Looking good nice color!I am still putting mine together after fresh paint last winter.Keep the fresh paint pictures comimg.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 10-28-2012, 07:02 PM   #73
SONOSADSACK
” I am still putting mine together after fresh paint last winter”
Gillnetter you are moving at a pace I am familiar with
Finished painting the tub this week including blacking out the bottom. Base went ok but the clear, not so much. This stuff was thick and heavy like no clear I’ve sprayed before. I should have reduced it but wasn’t sure the reducer I had would work and as it was about midnight I couldn’t call anyone I knew to ask. My gun is set up for much finer or thinner material, like the base, so I kept spraying. I cranked up the air pressure and just poured it on. The end result was lots of orange peel and plenty of sags. Even had a couple of bugs decide to take a rest after the last coat. The worst part was when I turned the tip on my gun to spray with a horizontal fan for the tail light area. I quickly hung the gun up adjusted the rotisserie and then forget to turn the tip back before spraying the bed side. I was pissed.
The next day loaded up and going home.
Old 10-29-2012, 05:48 AM   #74
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Anyone know what the seats are from in the Dark Olive interior? Those look great
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-30-2012, 09:46 AM   #75
1ATony
Man.... is that looking good.
1ATony is offline   Reply With Quote
