Old 09-25-2011, 11:15 PM   #101
pro1955
pro1955's Avatar
Re: 55-56-57
Coy's 20x10 with 275 40/20's rear, 18x8 235 40/18 front. 72 Monte Carlo sub frame with 1 coil cut. Lowering rear leaf springs, need to run mini tubs and early Camaro rear end 60" wide. I will be adding a 3" c notch and 1" lowering shackle this winter, to get the back down alittle more.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 09-26-2011, 04:23 AM   #102
57 3100
57 3100's Avatar
Re: 55-56-57
Originally Posted by pro1955 View Post
1956 355/350 Camaro 10 bolt.
WOW. that is a beautiful truck for sure..
leonard
57 3100 is offline   Reply With Quote
Old 09-26-2011, 10:38 AM   #103
hotrod1
56 - autocross
hotrod1's Avatar
Re: 55-56-57
Hey Pro1955: How low is the lowest part of the front fender from the ground? Look good! Do you have any issues with it bottoming out anywhere?
hotrod1 is offline   Reply With Quote
Old 09-26-2011, 11:14 AM   #104
robozride
Re: 55-56-57
I also am going for that look... here is a pic of mine im running the same size tire and wheel in the front but went with an 18x10 in the rear and a little more side wall. Its a 74 firebird sub and had 2" hotchkis lowering springs in the front. It (had) them. the tires scrubed when turning at all so i changed the springs out to a new set of stock springs and it sits about 1" higher now with no clearense issues.
robozride is offline   Reply With Quote
Old 09-26-2011, 11:52 AM   #105
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 55-56-57
Robozride,
Nice looking truck, man. How about posting more pictures? The original poster wanted more info on these trucks and I think he's gettign it with all these discussions of stances and rim/tire sizes. I am loving it. Do you have a photo of the truck with the 1" taller stacne in front and the taller side wall? What aspect ratio tire are you running now?
Dan in Pasadena is offline   Reply With Quote
Old 09-26-2011, 03:45 PM   #106
pro1955
pro1955's Avatar
Re: 55-56-57
[QUOTE=hotrod1;4920463]Hey Pro1955: How low is the lowest part of the front fender from the ground? Look good! Do you have any issues with it bottoming out anywhere?[/QUOTE The only time it bottoms out is over a sharp edge bump is at freeway speeds. That is why I'm going to c notch it this winter. No issues with front and rarely bottoms in back as it is now. It has a great ride very smooth, I balanced the drive line, all new bushings front and rear. 40 series tires help out the ride.
Old 09-26-2011, 04:31 PM   #107
57 3100
57 3100's Avatar
Re: 55-56-57
lots of nice trucks here for sure....
all you guys wanting to do a c-notch in the future, make sure your center section, (pumpkin) wont bottom out on the wood bed floor.
i was going to c-notch my frame a few months ago, then took some measurements, and sure enough my rear pumpkin will hit the wood bed floor. so if and when i do notch my rear frame, i will need to cut a hole in the wood, or raise that area of the floor so it will clear. just a thought..
leonard
Old 09-26-2011, 06:41 PM   #108
jim-bob
Re: 55-56-57
.."Dan from Pasadena" did I overlook your truck? or have you not posted any pictures? Show some pictures please..
jim-bob is offline   Reply With Quote
Old 09-26-2011, 10:05 PM   #109
hb32
hb32's Avatar
Re: 55-56-57
Been too busy getting it road worthy fixing all the mickey items from the PO.
Here is what I have at this time.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 09-26-2011, 10:20 PM   #110
Dan in Pasadena
Re: 55-56-57
So, 'ya wanna see pictures do 'ya? That's a bed thing to tell me because I'm a bit of an attention whore with my truck - sad but kinda true. Seriously, I didn't post because it doesn't rank with any of the fine trucks posted on this thread so far. I'm working on it (or its working on me, I haven't decided yet!)
As purchased in May of this year:
Truck as she sits now:
Engine in As-Purchased condition:
Engine now (No, not rebuilt...well, a "Krylon Rebuild!) 283 runs GREAT:
Some Interior Stuff I've been working on:
Instrument Cluster:
Door Panel:
Old 09-26-2011, 11:55 PM   #111
hb32
hb32's Avatar
Re: 55-56-57
Mine won`t even make it to that Dan.
Old 09-27-2011, 01:12 AM   #112
Dan in Pasadena
Re: 55-56-57
It will eventually. Well, I assume you intend to keep at it. Mine feels like I never get ahead and yet when I looked at which picture to post I realize I've done more than I remember.
C'mon, let's see yours. I suppose jim-bob should see the truth about what he's likely to start with...unless he has a helluva a lot more money than either of us had to start!
Old 09-27-2011, 04:05 AM   #113
hb32
hb32's Avatar
Re: 55-56-57
In my case I bought it as a daily driver for a truck and something unique to replace a Cavalier. My thoughts are to get it roadworthy, safe and replace all the broken stuff. I will put a T5 in it and already have the trans with a spacer. I also have a pair of Fenton split manifolds for the 235 and hope to swap out the Rochester. There is no room left in the garage for another sunny day driver.
Old 09-27-2011, 04:20 AM   #114
57 3100
57 3100's Avatar
Re: 55-56-57
wow Dan, i didnt realize you have only had your truck since May..... you have come a long way in a short time....
leonard
Old 09-27-2011, 10:04 AM   #115
Dan in Pasadena
Re: 55-56-57
leonard
Hi Leonard,
Yup, just since May; only about four months. The main thing is I got a relatively good one to start except w/ 4 fugly rims & tires. I happened to have had the Torq-Thrusts & a Craigslist find got me good (if tall) rubber for $80. I did all fluids, filters, belts, hoses myself in an afternoon for under $100, then scored the valve covers & air cleaner for another $150 from eBay. Appearence wise that's about all I've done.
Mechanically & electrically is another story; an expensive story too because of labor but she
runs great now. I don't use it as a daily, but I COULD reliably and safely which is where I
wanted to get as quickly as possible
Old 09-27-2011, 10:56 AM   #116
jim-bob
Re: 55-56-57
..thanks for the pics Dan..I knew you had to have a good'un plus an organized shop..Now that's what I'm hoping to find..Did you have very much metal work to do?
I like the original stance the way it is..don't know if I would lower one..(maybe just a little
Old 09-27-2011, 11:39 AM   #117
Dan in Pasadena
Re: 55-56-57
..thanks for the pics Dan..I knew you had to have a n organized shop....
A little over 100 posts and you're making fun of me, huh? Lol. Yeah it's a disaster right now. LOTS of work needed there.
Funny you ask right now. I was working on the driver's door yesterday and I found rust-out in the bottom of it. I'm debating if I should stop, pull both doors and send them to a blaster? But that's a slippery slope because I'm wondering what it'll cost and if I should/could afford to pull the bed off too? Kabwe has a local blaster he trusts so I need to drop him a PM for a name & number.
I'm planning on lowering it SOME but not slamming it. I'm thinking maybe 3" lowering rear springs and a 3" drop axle in front. Then if it's not low enough in front I can pull a leaf or two.
Old 09-27-2011, 02:31 PM   #118
LDO
LDO's Avatar
Re: 55-56-57
Didn't rank???
Quit painting with the garage door closed Dan!
Your truck is looking really good! Love the paint and wheels!
I've only had my truck for a few months too but its easy to lose track of time when you are in the shop having fun.
Good job.
LDO is offline   Reply With Quote
Old 09-27-2011, 03:57 PM   #119
Dan in Pasadena
Re: 55-56-57
Originally Posted by LDO View Post
...Quit painting with the garage door closed Dan!
Huh? Uh, oh yeah. Good idea, ha ha!
Thank you for the compliment. I really appreciate the kind words. I'm trying, man. There just aren't enough hours in a day or days in a week.
Come on guys, let's see more b!tchin trucks!
Old 09-27-2011, 04:18 PM   #120
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 55-56-57
Okay here are some from a couple of guys at the local cruise nights.
Kabwe is offline   Reply With Quote
Old 09-27-2011, 04:58 PM   #121
Dan in Pasadena
Re: 55-56-57
Whew! Bam, Where's this cruise night? I've gotta get over there and see these beauties.
Not to go completely off topic but can you drop me a PM with the name/location of the blaster you use...again? You told me once but I lost it, natch! Looks like I need to do my doors before I proceed much more on them.
Old 09-27-2011, 05:25 PM   #122
hotrod1
56 - autocross
hotrod1's Avatar
Re: 55-56-57
why PM. Let everyone know.
Old 09-27-2011, 05:37 PM   #123
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 55-56-57
Dan,
Here you go.
Blasting Specialties
2937 Vail Avenue
Commerce, CA 90040-2615
(323) 721-5020
Old 09-27-2011, 05:49 PM   #124
Dan in Pasadena
Re: 55-56-57
Thanks so much. Any idea what blasting two doors will cost? I'm wondering if they'll blast down inside? I MAY send them my bed too. When you do beds, do you fully disassemble before you take it to them?
Old 09-27-2011, 06:36 PM   #125
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 55-56-57
Well when I did my cab they change me 250 inside and out. If was was going to do the bed I would disassemble it.
