Closed Thread
Old 09-28-2011, 07:22 AM   #26
FFredo
Re: What Did You Do With Your Truck Today ?
I finished mounting the new gas tank between the frame rails. Just need to plumb it and decide if I'm going to a electric fuel pump.
FFredo is offline
Old 09-28-2011, 12:17 PM   #27
duwem
duwem's Avatar
Drove it 15 miles to work this morning. Drove it yesterday too.
duwem is offline
Old 09-28-2011, 12:54 PM   #28
Daze57
Daze57's Avatar
nice work on the repatching
Daze57 is offline
Old 09-28-2011, 05:52 PM   #29
Red Foreman
Red Foreman's Avatar
Just got my frame back from the sand blaster, after blowing off the excess sand & a quick prepsol wipe down my work colleague hit it with LIC industrial low gloss 2K.
Red Foreman is offline
Old 09-28-2011, 07:38 PM   #30
Lrall
Lrall's Avatar
Bought one of these http://www.summitracing.com/parts/PRF-60122/
So that it will run
Lrall is offline
Old 09-28-2011, 08:42 PM   #31
codger30
DUWAM, you win, that's what it is it all about, driving your car.
I miss my '37 chev sedan, that was a daily. Oh well, got to get the '48 pickup finished.
Bryan
codger30 is offline
Old 09-28-2011, 09:22 PM   #32
Indian113
Indian113's Avatar
Red Foreman,Your frame is looking great!!! Are you going to start a build thread?
Indian113 is offline
Old 09-28-2011, 09:33 PM   #33
mknittle
mknittle's Avatar
I painted my steering column parts.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 09-28-2011, 10:09 PM   #34
Coupeguy2001
Coupeguy2001's Avatar
I fabricated all but one of my hydroboost lines. The left frame rail is getting really busy. I finally found adapters to install the proportioning valve, and installed clamps for the brake lines.
Now if I can just find a rebuild kit for the master cyl. I can finish assembling that.
Bought the firewall paint and talked to the painter about fenders and inner fenders.
Looks like I need to get a few parts stripped.
Coupeguy2001 is offline
Old 09-28-2011, 10:54 PM   #35
55metalmonkey
Red Forman: lookin good
55metalmonkey is offline
Old 09-28-2011, 10:59 PM   #36
Red Foreman
Thanks Indian113, I've been holding off on doing a build thread untill I have progressed a little but now that you asked I feel its time!!!
Old 09-29-2011, 06:45 PM   #37
flatbed51
flatbed51's Avatar
Did not do anything with my truck today, but I worked on my car hauler so I can take the frame to my buddies shop to put on his rotisserie to finish welding in Malibu clip.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline
Old 09-29-2011, 07:49 PM   #38
FFredo
I sourced the cross sill material for the flatbed build. Feeling pretty sure about major progress this weekend.
FFredo is offline
Old 09-29-2011, 08:16 PM   #39
mknittle
mknittle's Avatar
I painted the rest of my steering column parts and measured and measured and oh yeah measured again for rear suspension placement.
Mark
My GMC build.
mknittle is offline
Old 09-29-2011, 08:28 PM   #40
Russell Ashley
Russell Ashley's Avatar
Got my cluster, new ignition switch, light switch, and electric wipers installed, got most of my under-dash wiring done. I'm not using a late GM steering column like the EZ-Wire harness is designed for so it's going a little slower than I wanted.
What does the "lock" position on the ignition bezel do? New ignition switch, key turns backward to what I thought was accessory position, but bezel says "lock". and no power to accessories in that position.
Russell Ashley is offline
Old 09-29-2011, 09:58 PM   #41
lazypineapple
lazypineapple's Avatar
I got my wheel spacers today for my rear wheels.
I had 1" hub centrics made. needed to get the 245/60 away from the bed a little.
looks closer than it is.
lazypineapple is offline
Old 09-29-2011, 11:29 PM   #42
solidaxel
solidaxel's Avatar
Fixed the gas pedel where the rod goes theu the floor and carpet and I think I gained at least 50 more HP at WOT !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline
Old 09-30-2011, 12:39 AM   #43
Atommik
Atommik's Avatar
Worked on straightening the right rear fender...loaded right front fender into my suburban to bring to work tomorrow to see if I can "adapt" a BMW HID headlamp to work in my 1951 pick-up!
Atommik is offline
Old 09-30-2011, 12:53 AM   #44
relaxedsierra
relaxedsierra's Avatar
dropped off my new steelies at the powdercoaters
relaxedsierra is offline
Old 09-30-2011, 01:46 AM   #45
Coupeguy2001
Russell, it usually means that you have a passenger car ignition switch instead of a truck unit.
The problem is that some money grubbing soul determined that they were interchangeable, and the truck units don't seem to be getting reproduced anymore, yielding our plastic ignition switch placards incorrect for the switch.
I don't think the passenger car position indicators match very well, which is why I stubbornly installe a brand new truck plastic piece on my brand new passenger car ignition switch on my '57 truck.
Anyway, I sanded my firewall for a couple hours, and got really bored with that, and painted it anyway. You can't see where I stopped sanding, because Iadded some hardener/accelerator to the paint and it kicked pretty fast so I hand buffed it at the sanding edge, so that is good. Someday, I will get it painte right.
It looks nice with fresh paint under the hood.
I blasted the inner fender panels and used a file to clean up the area where I used the die grinder to open them up to clear the upper control arms.
It appears someone cut them with tin snips while they were installed to get to the back side of the upper shock absorber bolts. I cut that area out, and will probably add some metal or rubber there.
It's coming along.......I got my aluminum water pump today, but unfortunately it isn't much lighter than the cast iron one. I'm still planning on the aluminum heads, aluminum water pump, and aluminum radiator to raise the front up about 1/2"-3/4" to make it look better.
Setting the old Iron head engine in it without the bumper and grille made it low, so this can only help. If it doesn't work, I will just have to either go big block springs or have the current ones re-tempered.
I bead blasted the horn relay, and it looks new. I am going to use the old original voltage regulator holes to mount a master cylinder reservoir.
I now have so many tubes along the left frame rail that it looks like an aircraft wheel well. I am only going to add a fewmore, I need a vent line for the stick portion of the trans and a vent line for the overdrive portion, and master cylinder remote line.
Maybe I will run the vents under the bed, or to the right side.I acquired a 2 3/4" big brake set-up for the rear, but the backing plates are so rusty that I should have them either dipped or sand blasted. Since I bought new shoes for the 2 inch brakes, I will run those for a while. I used the spring kits for the big brake set-up on the smaller brakes since it was new.
I also cleaned up the area around the truck really good because the Boss was coming back today and he likes a really nice clean facility.
The airplane is back, I need to work on it, so no truck work till it leaves again.......
Old 09-30-2011, 04:26 PM   #46
Russell Ashley
"Russell, it usually means that you have a passenger car ignition switch instead of a truck unit.
I don't think the passenger car position indicators match very well, which is why I stubbornly installe a brand new truck plastic piece on my brand new passenger car ignition switch on my '57 truck."
Now I remember. I had forgotten about Chevie's having that style ignition. Since I already had the bezel with "lock" printed on it and since my new switch was actually a car switch anyway I went back over to the Classic Chevy parts store and got a car tumbler. I like it.
In case anyone didn't know this, you can remove the key when it's in the "off" position and start the vehicle using the knob. The "lock" position locks it.
Old 09-30-2011, 10:06 PM   #47
bajabob
bajabob's Avatar
poured an adult beverage and wire wheeled brake parts... maybe paint them tomorrow...
bajabob is offline
Old 09-30-2011, 10:44 PM   #48
Tchia65
I drove mine to Lowes to get materials to finish moving in and setting up the garage so I can keep her inside. Along the way I dropped it on the rockers to make a toyota look bad, and beat a mustang light to light because he was a punk and irritated me.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline
Old 10-01-2011, 04:37 AM   #49
Daze57
Daze57's Avatar
started hand bending steel fuel line from fuel pump to the carb (i have a hand bender tool but all the bends i mark went the wrong way lol -got pretty close to what i want just gotta tweek it a l'il more. - uncle jack is callin me again
tomorrow is master cylinder day -bench bleed and install - bleed brakes all around 4-5 times .- check that off my list .
Daze57 is offline
Old 10-01-2011, 10:00 AM   #50
mknittle
mknittle's Avatar
Looks like rain so picking up and covering up.
Mark
My GMC build.
mknittle is offline
Closed Thread
