Old 10-17-2011, 10:08 PM   #1
creepdogg
Help me identify my rear
I know theres about a million threads about this, hell I have just read about 30 or so, but cant seem to figure it out, I am powdering my rear, swapping from 6 lugs to 5 and installing a stock 71 c10 posi unit into this rear.
Originally its out of my 1970 c10 coil 2wd 6 cylinder truck, running 3.73 gears, I want to replace all the bearings as well as seals.
Can someone help
tks
creepdogg is offline   Reply With Quote
Old 10-17-2011, 11:03 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Help me identify my rear
I don't understand your question....sounds like you have a 70 rear end and you want to install 5 lug axles??...Is that correct? I'm sure others know, but to my understanding the 70 axle housings could be either a narrow or wider housing pending on its production date....the 67-70(early) were approximately 3/4" per side or 1.5" narrower than the 70(late)-72 rear ends....if by chance you have the later rear, you maybe able to swap in axles from a 71/72 truck or buy the ECE conversion axles or check with Moser(?)
So...please measure from backing plate to backing plate....this will help determine
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-17-2011, 11:31 PM   #3
creepdogg
Wow! How I messed that up, I need to know if it is a Dana rear or a HO35. When buying bearings for the rear axles and diff carrier I get lots of options regarding Dana rear ends and HO33,35. I am not sure what one I have?
Old 10-18-2011, 12:43 AM   #4
crazy longhorn
Fabricate till you "puke"
GM 12 bolt truck...
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-18-2011, 01:16 AM   #5
Mike Bradbury
Mike Bradbury's Avatar
longhorn got it but this might help explain the difference for you.
http://coloradok5.com/axleguide.shtml
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 10-18-2011, 09:06 AM   #6
creepdogg
Thanks guys, so its def not a Dana rear, tks
Old 10-18-2011, 09:24 AM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
nope...looks like a....
GM CORPORATE 12-BOLT
The stronger 12-bolt, with an 8 7/8-inch-diameter ring gear, can be found in various 1964-82 GM 1/2- and 3/4-ton rearends.
Geoff with a G
