Old 10-25-2011, 07:58 PM   #1
webfoot
NP205 speedometer gear housing removal
I have a new one of these but my 1 1/8" impact socket won't fit in there because of how close it is to the case. Before I waste money on a regular wall 1 1/8" socket will this fit or does it take a special tool?
Also, what is the size of the nut on the output shaft yoke?
Trying to get this thing from dripping gear oil all over my driveway!
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-25-2011, 11:19 PM   #2
'63GENIII
'63GENIII's Avatar
Re: NP205 speedometer gear housing removal
I think I took a grinder to the part of the socket that hits the yoke. Some would say it weakens the socket which is probably true, but mine hasnt broken yet. Just had to thin out the wall a little to get it to fit in there>
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-25-2011, 11:48 PM   #3
jbclassix
Junk Yartist
jbclassix's Avatar
get a set of chrome Pittsburgh sockets from Harbor Freight. them grind the taper of the end of the socket also. Use one of their coupons too. It's handy for other fittings and things... I have a link below you may find somewhat helpfull
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-26-2011, 12:32 AM   #4
webfoot
I have actually looked at that before and found a lot of useful info. It is threads like this that helped me (successfully) rebuild the M-21 in my GTO. I wish I had time to take the whole thing out and rebuild it. For now I am just going to replace those 2 gaskets and the seal in that housing. I got a craftsman 1 1/8" socket that is pretty thin so I am hoping that will work.
-me
