10-26-2011, 08:47 PM | #1 |
'47-'54 radiator frame pics
Can someone help me out with a few reference pictures? My '50 3/4 ton chevy is missing the two rod braces that attach to the front top of the radiator frame and go down to the lower radiator shroud. I believe they go down and forward and atttach near the lower grill????? ANy help with a few pictures and dimensions would be greatly appreciated. Thanks in advance.
John |
10-26-2011, 09:33 PM | #2 |
Re: '47-'54 radiator frame pics
The only thing I remember is that one is longer than the other !!
10-26-2011, 09:49 PM | #3 |
Solid.....
Do they converge off to one side on the lower shroud? I have two holes there that are set off to one side? |
10-26-2011, 10:41 PM | #4 |
they go from the firewall to brackets on inside of the wheel wells.
10-26-2011, 11:34 PM | #5 |
sorry wrong ones. i will look tomorrow we should have one i can get a pic of.
There are tow pairs one is a x brace and the other sounds like you described i tried to get a pic but it's too dark. Last edited by mknittle; 10-26-2011 at 11:49 PM. |
10-27-2011, 05:16 PM | #6 |
10-27-2011, 06:54 PM | #7 |
Sorry about that I just remembered.
I went to my cancer doc this morning and that disrupted the whole morning. brain cancer messes with my memory somtimes Last edited by mknittle; 10-27-2011 at 07:08 PM. |
10-27-2011, 07:05 PM | #8 |
Got some hope they help, They are two trucks the 48 dosen't have the x beace but has the radator support to splash pan braces.
The other is a 52 and has both splash pan and x braces |
10-27-2011, 07:10 PM | #9 |
let me know if you need more.
Mark |
10-27-2011, 08:25 PM | #10 |
That is what i was looking for. Would it be to much to ask for the 2 lengths?
I guess i'll try and make a couple from some barstock. Thanks Last edited by coralhead; 10-27-2011 at 08:34 PM. |
10-27-2011, 08:50 PM | #11 | |
If you are going to make them I can make you a drawing tomorrow. that will help with the angles and bolt placement. |
10-27-2011, 09:21 PM | #12 |
That would be great. I really appreciate the help.
10-28-2011, 01:12 PM | #13 |
I was going to make a drawing but decided that pictures would be better.most of the pictures rae of the left but the right the same but shorter and the lower end turns the oposite derection.
10-28-2011, 01:18 PM | #14 |
some more. oh the rod is 3/8 dimater.
10-28-2011, 01:22 PM | #15 |
if you have any qustions let me know.
10-28-2011, 06:03 PM | #16 |
You went above and beyond. Greatly appreciated. Thanks
10-29-2011, 12:41 AM | #17 |
it was pretty easy really, the front sheet metal was already off the truck I borrowed them from. I just took out 2 bolts.
10-29-2011, 07:03 AM | #18 |
Old Heap Driver
^^^^^Ditto^^^^^
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
10-29-2011, 10:59 AM | #19 |
Glad to help.
