10-14-2011, 12:28 AM | #1 |
ls motor mount adapters
i have a 5.3 motor I'm putting in my 85 crew cab 4x4 so my question is what is the best motor mount adapter? or should i just make my own? im going to be using the stock exhaust manifoilds and ac will stay in the stock location on the 5.3 motor... i know i will have to trim the frame but what motor mount adapter will work the best? from what i can see some move the motor forward 2'' and some let it bolt into the stock location? I'm making new drive lines so the tranny and T case location shouldn't matter. Any help would be appreciated.
10-14-2011, 01:16 AM | #2 |
Re: ls motor mount adapters
HER makes adjustable ones. They sell for 200$.
82 chevy longbed(grey truck)first truck when i was 15! |
10-29-2011, 07:04 PM | #3 |
Home Built '87
Dirtydingo.com also are adjustable mounts.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
10-30-2011, 09:37 AM | #4 |
thanks for all the info! but im just gonna make some. i'll post some pics as i go.
10-30-2011, 09:39 AM | #5 |
Gonna have enough power with a 5.3?? Buddy has a Tahoe with that motor and isn't really anything special....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-30-2011, 09:57 AM | #6 |
its not the motor i wanted... but it was cheep and it came from the same truck as my dash. i will get a 6.0 sometime down the road. i don't tow that much so not to worried about it plus it will have more power than my 97 350 vortec motor i was going to use
10-30-2011, 10:09 AM | #7 |
Formerly- 1972SuperCheyenne
I used the $30 swap mount plates on ebay for my 6.0 build. Clutch fan fit in stock fan shroud, A/C fit in frame perfect, etc... The expensive mounts are a waste of money in my opinion. The cheap ones work perfect. Search
The 6.0 Silverad build for pics.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-30-2011, 08:32 PM | #8 |
Pacific Fab makes a really nice set-up for 4x4's & that's what we went with in my K30.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
10-31-2011, 09:27 AM | #9 |
