11-01-2011, 10:49 PM | #1 |
Hope I don't screw this first post up! Trim moulding
I've been looking for the front hood edge trim for my '68 and ran across this but didn't want to post in the for sale area. The whole set of lower trim and it looks like the emblems are there as well. He says it's OEM. Does the lower trim fit the blazer's as well?http://www.ebay.com/itm/140628637524...9#ht_500wt_949
11-01-2011, 10:52 PM | #2 |
Lucky Teter at the wheel
Re: Hope I don't screw this first post up! Trim moulding
You did.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
11-02-2011, 10:40 AM | #3 |
Restoration Virgin!
Come on Drew...that's not a very helpful response???
First off, to the boards from NC.....I've moved this thread over to our blazer forum so the guys there maybe able to answer your question....that does look like a nice set of 67/68 trim....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
11-02-2011, 11:50 AM | #4 |
Junior Member
Only side mouldings that would fit from this eBay set is on the fenders and doors. Blazer rear quarter sheet metal is different than a truck from the doors back. If you think about it, a truck uses two pieces between the doors and the rear wheel opening (cab and bed) - blazer uses one piece. The two little pieces in the lower box are for the cab - a blazer doesn't have a cab. I believe the side moulding behind the rear wheel opening is different truck/blazer as well.
Something else to note is that the eBay trim is for a 67-68 truck. Although some pieces may fit, blazers weren't made by GM in 67 and 68 so you will not find a complete set of these mouldings in this style for a blazer. The blazer side trim you will find from vendors is the later style that does not go over the wheel openings. ...and only the lower. GM did not put upper side trim on blazers. That being said, I would still like to see the 67-68 side trim applied to a blazer with the 68 front clip.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
11-02-2011, 12:38 PM | #5 |
Restoration Virgin!
stomper...first blazers were made in 70, right? I've seen guys put 67/68 trim on 69-72 pickup trucks, but it just didn't look right to me...I'd be interested in seeing it on a blazer though...maybe someone can photoshop one??
11-02-2011, 03:53 PM | #6 |
I'll move over to the Blazer post but I'm work on putting a '68 clip on a '70 Blazer and liked the '67-'68 trim and thought it might work but you guys are talking me out of it. To much custom stuff already invested in it. See you on the Blazer side. I miss my '68 396 4spd SWB. Somebody else could use the trim.
11-02-2011, 04:34 PM | #7 |
Restoration Virgin!
I hope I didn't confuse you....I have already put this thread in the blazer forum for ya....it's the most appropriate are for your question...that's why I moved it...so if you want more input, keep bringing it to the top...I'm sure someone else has had the same thought
11-02-2011, 04:41 PM | #8 |
I believe the wheel base (and hence the wheel openings and trim lengths needed) are different. Pretty sure my Blazer is 104" and shortbed is 115".
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
11-02-2011, 06:27 PM | #9 |
Welcome to the boards from Philly.....luckily the side trim is longer for a pickup, all you have to do is cut it down alittle
I just picked up a 68 hood w/ moulding, if you need it give me a shout....not the hood just the moulding lol
