HID headlight ?'s
I just got my wife a fully loaded 2007
![]() Thanks Jake
1968 GMC 3/4ton LWB 2X4 1995 Chevy Tahoe 2dr 4X4 (sold) 2007 Nissan Altima 3.5 (traded in) 2002 Jeep Grand Cherokee 4x4 2007 GMC Yukon 4x4 (wife's) |
Parts and more parts
Re: HID headlight ?'s
Look at DDM Tuning for a shoice or look at the vendor support listed on this website.
Frank |
#3 | ||||
I know this is a somewhat old thread, but I figured I'd throw in some info to help if you haven't already figured it all out and to maybe help someone in the future who may be looking at this thread.
Some people really want some Blue in their HIDs. All HIDs in the 4300 – 12000K range are going to produce a shade of blue. Even 4300K will have a slight tint of blue. I recommend staying below 5000K, but that’s not enough blue color for some. 6000K is the happy medium for those who want some visible blue color, yet still have a white light. Higher than that and the lights start to become very blue and are more likely to attract unwanted attention from law enforcement. ![]() Quote:
I would also recommend disabling the daytime running lamps on the Yukon. Your DRLs run the headlights on reduced power. This reduced power can harm the HID ballasts. I'm not certain, but I believe that it's just a matter of pulling a fuse on your truck. Your truck uses the H13 (aka 9008) bulbs which handle both high and low beam functions. I know that with DDM Tuning at least, you have 2 HID options. The first is to buy a single beam HID kit that would only work with your low beams. For $20 more, you can have a kit that also has high beam functionality. The HID bulb is on a sort of plunger base. When you turn your highs on, it pops the bulb out a bit (or maybe it's in, I can't remember). I don't think it makes a huge amount of difference, but it's good to have the functionality. I would recommend the latter, of course. |
Tot Roddin'
Great info 1badgmc!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
The problem I have with HID's in a housing made for regular bulbs is the size of the light source. The HID capsule is large, and the whole thing glows like a florescent when lit. An incandescent bulb has the small filiment as the light source. The reflector is designed to capture light from the light source and redistribute it where it needs to go for a proper beam pattern. The large HID light source in a reflector made for a small filiment sized light source can't properly distribute the light for a useable beam pattern. There will be too much glare, and oncoming traffic will be blinded.
If you don't have a cut off pattern like this on low beam, you're blinding oncoming traffic. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
It is possible to have HIDs in a non-HID housing without causing dangerous glare for other drivers if you take care with them. My eyes are extremely sensitive to light, so if your lights aren't bothering me, they're not going to bother most other people. I do take care with mine and I've made sure they don't bother me. I have seen a lot of drop-in HID conversions driving around that didn't bother my eyes at all. Unfortunately, I've seen more that DO bother me and those are the ones that give the rest a bad rap. I have 2 trucks that I've put HIDs in without causing pain to other drivers. I also have OEM HIDs in my CTS with a beautiful cutoff, so I know what a good pattern looks like.
Will drop-in HIDs ever be optimal in non-HID housings? No. Never. But it is possible to install HIDs WITHOUT dangerous glare to other drivers and have brighter, whiter lighting at night. |
I ended up getting 6000k HID's I don't remember the brand but we love them and they work awesome, I did have to adjust my lights so I wasn't blinding oncoming drivers. The only complaint is the shop that sold them to me told me they were hi/low beam HID's and they are only HID in low, I bought them in Arizona on my way to Washington so I didn't get a chance to talk to the shop after I installed them. It was a pain getting them in without removing the bumper and I had to trim the plastic just a bit to get them to fit correctly. I think I paid $94 for them and I'm planning on getting a set for my Subaru
any pics of your output? beam pattern? normally HIDs in normal headlight glare like crazy
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#9 | |
