Old 12-01-2011, 10:45 PM   #1
irgo2310
Unhappy 1972 c10 chevy truck troubleshooting!
Alright guys, I am a newcomer at this time. I am having a lot of trouble with my truck. The problem is that my 72 c10 with a 402 big block, starts with no problem, until I put it in gear, either drive, or reverse, then it just shuts off! Can anybody help, please? I really need someone to help me out!
George!
irgo2310 is offline   Reply With Quote
Old 12-01-2011, 10:51 PM   #2
BMERDOC
BMERDOC's Avatar
Re: 1972 c10 chevy truck troubleshooting!
Any recent repairs or changes to your combo?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-01-2011, 11:08 PM   #3
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
welcome to the site my neighbor to the north!
Is your truck running smoothly before you drop it into gear? Do you know the idle speed before you put it in gear? As Bmerdoc asked is there anything new or changed? It may be a simple carb adjustment
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 12-01-2011, 11:38 PM   #4
Autoblueprint
Autoblueprint's Avatar
Lightbulb Re: 1972 c10 chevy truck troubleshooting!
Inside the POINTS type distributor there is a black wire and a brown wire, one goes to the coil and one to ground, sometimes the wire ( usually the black wire ) is broken but you can't see it with the naked eye. Check for continuity on each wire with an ohm meter as you wiggle the wire, if the meter reading reading goes OL ( loss of signal, i.e., an open circuit ) then that is your problem. Replace the distributor.
If it is an HEI, check the green and yellow wires at the pickup coil inside the distributor. Same fix, replace the distributor.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 12-01-2011, 11:45 PM   #5
Wrenchbender Ret
Try increaseing the idle speed.
Blueprint brings up a good possibility but here in the Midwest we replace the wire or the pickup coil & not the whole dist.
Wrenchbender Ret is offline   Reply With Quote
Old 12-01-2011, 11:47 PM   #6
irgo2310
Not really other than a carburetor kit!
Old 12-01-2011, 11:48 PM   #7
irgo2310
Not really BMERDOC!
Old 12-01-2011, 11:50 PM   #8
irgo2310
Yep, CHEVYTRUCKLUVER, the idle is fine, it cranks up like a rocket, the problem is when I put it in drive, or reverse then, it just shuts off. I can keep it running if I used both feet, on foot on the break and the other on the gas!
Old 12-01-2011, 11:52 PM   #9
irgo2310
Thanks AUTOBLUEPRINT, I will try it out and see what happens!
Old 12-01-2011, 11:58 PM   #10
irgo2310
Thank you WRENCHBENDER RET, I will try all these tips out. Hopefully, I will get my baby running again. I really need it running, this is my new project, is ready for a paint and interior job.
Old 12-02-2011, 12:13 AM   #11
PHAT TONY
PHAT TONY's Avatar
If your torque convertor decided to lock up this could possibly happen.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-02-2011, 01:20 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Look around the intake manifold for an open port where a hose might go. You might have a large vacuum leak. If you just put in a carb kit you may have missed a port. If you have a vacuum gauge then put it on a manifold port and try to read around 18 inches of vacuum.
Do you have a brake booster? If so then pull the hose off of it at the manifold and plug the port. A bad brake booster will cause a vacuum leak. Vacuum leaks will make the engine run faster and
when the idle is turned down to compensate, then the off idle acceleration is affected and the vehicle will stall.
Block up the rear end and repeat the procedure. Check your timing. Retarded timing will give these symptoms.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-02-2011, 10:06 AM   #13
Indyuke
^^ I agree with the above. If you can keep it running by keeping your foot on the gas, then it's not a problem with loss of continuity in the ignition circuit. More than likely a timing issue, vac leak, carb adjustment, etc. Something is maladjusted rather than broken.
Indyuke is offline   Reply With Quote
Old 12-02-2011, 01:26 PM   #14
NewAge1970
NewAge1970's Avatar
i had this same problem with my 350/700r4 combo. intake leak was my problem. ran fine at idle untill it is put in gear and then it wouldnt keep up an idle. or try the carb kit idea, or possibly even a carb gasket.
"Its better to burn out than it is to rust!"
'70 GMC C10 2wd. 2.02 aluminum heads. TH400 trans. 450WHP
'04 Nissan 350z DD, Twin Turbo, 600whp, drag beast!
NewAge1970 is offline   Reply With Quote
Old 12-02-2011, 02:17 PM   #15
MARKDTN
X3. Look for a large vacuum leak-brake booster or carb gasket come to mind but there are other small hoses too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-02-2011, 08:16 PM   #16
irgo2310
Thanks, PHAT TONY!
Old 12-02-2011, 08:17 PM   #17
irgo2310
Thanks, Vettevet!
Old 12-02-2011, 08:18 PM   #18
irgo2310
Thanks Indiuke!
Old 12-02-2011, 08:19 PM   #19
irgo2310
Thanks, New age 1970!
Old 12-02-2011, 08:21 PM   #20
irgo2310
Thanks, Markdtn!
402, 72 c10, lwb bed chevy 1972
