07-06-2010, 12:57 PM | #51 |
Re: Adjustable rear trailing arms how-to
How far is it from the end to where the bend (angle) starts?? I would like to build these, but I dont have any arms to use as a template. Awesome work everyone. I plan on putting this TA suspension on my 1957 truck.
07-06-2010, 03:27 PM | #52 |
I would highly recommend finding some OE arms to use as your template & not rely on internet provided measurements because the 'bend' is very mild making it hard to be 100% accurate (one guy measures this way while another measures that way).
07-06-2010, 03:35 PM | #53 |
Very true Scoti....do you know of anyone that might have some they want to get rid of or that I might be able to use as a template?? I see you are in Dallas I am in Corinth about 30 miles north of you. But, seeing how they are some what adjustable one could always just adjust them where they need to be, if the measurment was not botched.
07-06-2010, 05:29 PM | #54 |
I'll try and measure mine. the point where it starts to bend is a little difficult to get exact but I think there is enough adjust on how you build it to make it work. I am sure that the angle was 15 degrees where it kicks up. Ill measure tonight and let you know what I come up with!
I have a stock set of arms painted with new bushings if anyone wants them let me know... |
07-06-2010, 05:31 PM | #55 | |
07-06-2010, 05:43 PM | #56 |
07-06-2010, 06:02 PM | #57 |
Not a problem. I'm real close off of 635 in the Garland area to give you an idea on travel.
07-06-2010, 10:54 PM | #58 |
Ok, cool that is actually not that far. I have another problem at the moment, was going to weld in my Trans Am clip and noticed that it looks like it is more to one side, (giving it the ole eye ball measurment) but it is aligned with the frame rails on the inside. So, who knows. I measured 24 times then tacked it in place.......a little frustrated at the moment.
12-06-2011, 12:51 PM | #59 |
I forgot about this thread and came across it searching around. I wanted to post a pic of my arms finished and see what you thought!
12-06-2011, 02:21 PM | #60 |
I don't like this forum anymore! Yall give me these ideas that get stuck in my head so that I eventually have to spend more money for parts I didn't know I needed, and go out in the shop and spend more time making upgrades that I didn't know I needed!
Seriously though, slick work on the trailing arms! I just may have to do this on my '66.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-06-2011, 06:01 PM | #61 |
I hear that, I started out with just a nice little drop and clean it up a little............. 4 years later and I dont even want to know how much Im still not even close to being done! lol
Thanks Im pretty happy with how they came out! |
12-06-2011, 06:47 PM | #62 | |
HAHA!!! I know what you mean! Check out what i had to build after i read this thread...
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
12-06-2011, 07:25 PM | #63 |
Way cool! I wish I would have thought mine a little more through and I would have adjusted the angle where the rear end bolts to, so it would correct my pinion angle.........
12-07-2011, 03:43 AM | #64 |
dnd1978 - what size tube did you use for your trailing arms? 1.75x.120?
12-07-2011, 09:39 AM | #65 | |
Yes, tubing is 1.75x.120. bag plates are .250 diff. mounts are 2 pieces of .120 steel plate welded together = 3/8 thick. I had more pictures but then I upgraded the S/W on my iphone I lost them all…
03-21-2012, 06:46 PM | #66 |
Just came back to tthis thread for a bit and there si some really neat ways of doing this mod!!! congrats to everyone that has taken my idea and gone wild with it!!!!!!!!!!!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
04-10-2013, 02:47 PM | #67 |
Hmmm....I've got a good welder, a cheap angle finder, and a wife that just went back to work. I think I'll have to seriously consider this instead of upgrading my old arms.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
03-09-2014, 04:32 PM | #68 | |
This is what I was thinking too. Good fab work guys and thanks for sharing info.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
03-10-2014, 08:20 AM | #69 |
I'm no expert, but wouldn't rectangular stock be stronger than cylindrical in this application?
1968 LWB C20 / AC / Wood Bed |
08-17-2016, 09:36 PM | #70 |
don't know how I missed this one way cool
01-25-2017, 07:41 PM | #71 |
I am building a set of trailing arm's for my 1970 GMC 3/4Ton Truck. It came with Leaf Springs on it but also had the OE trailing arm crossmember already in place in the frame. So i'm going to build the trailing arm's myself. I'm going to be using Steel 3 x 2 x .180 wall 6 foot long. I Really Need a Blue Print of it. But any HELP, measurement's or angle's would be Really Grate. Cause i have nothing to go off of your by. Thank you in advance.
06-19-2020, 10:13 AM | #72 |
Old thread i know but I just read: "A wife that WORKS"????? You lucky ......! That is the answer to ALL of my prayers! I've been trying to get her to try that now for about 10+ years. It sure would make it easier to get the truck done But, it aint looking too good. lmfao
