Old 11-26-2011, 10:29 AM   #1
nickacf7
Frame ??
Hello all, First time poster here. I am looking to build a chevy short box 4x4 for a dune toy. My question is, will a 4x4 frame from a 73-87 bolt up to a 67-72 body? Will there be any issue's in doing this if it would work?
Great forum! Thanks, Nick
nickacf7 is offline   Reply With Quote
Old 11-26-2011, 12:56 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Frame ??
First off, Welcome to the board. Yes, it can be done. There are a handful of frame modifications that are need for a 67-72 body to mate with a square body frame. For starters the body mounts on the frame are different. I've never done this, so I not sure of all of them. I recommend doing a search under this board (4x4 section) to find the folks that accomplished this mod.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 11-27-2011, 03:57 PM   #3
nickacf7
Re: Frame ??
ok thanks, yeah I did a little research but did not find a whole lot on it. I will try again
Thanks, Nick
Old 11-27-2011, 04:49 PM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: Frame ??
Hello to a fellow Michigander! Silver Lake is one of my favorite places to wheel--- anything!
Check out my 4x4 build, that will help a bit.. There is a pretty extreme "kickup" in the later model frame that you'll need to compensate for, the front clip mounts will need to be moved to center the tires in the wheelwell too.
Good luck and post pictures!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 11-27-2011, 09:34 PM   #5
nickacf7
Re: Frame ??
thanks that gave me a good idea of what it will take to make it work. It will be a little while till I start my build, I'm just getting ideas. I would like to find a short box 4x4 but they are hard to find. A guy at my work has a 67 4x2 and I was thinking I could put an axle underneath it with a coil over suspension. But he said the body is pretty rough, so we'll see how it pan's out.
Old 11-30-2011, 09:38 PM   #6
propanemudtruck
Re: Frame ??
With all the length of the long box frame I cut up for my project, it ended up the same wheelbase as my 89 K5, plus or minus a 1/4". picks of your buddy's truck?
-Kevin
Old 12-12-2011, 11:36 AM   #7
Mudder
Mudder's Avatar
Re: Frame ??
I done mine back in 86 and have really had no problems. I would like to upgrade the brakes at sometime. I am running all disks with the orginal master and booster. It works but I have to change the master every couple years.
Mudder is offline   Reply With Quote
Old 12-12-2011, 11:47 AM   #8
Mudder
Mudder's Avatar
Re: Frame ??
Here is a picture/w street tires.
Old 12-14-2011, 10:20 PM   #9
70custom20
70custom20's Avatar
Re: Frame ??
Someone correct me if I'm wrong, but isn't there a 4" wheelbase difference between the two? I believe the W/B for the 67-72 longbed is 127" while the wheelbase is 131" for the 73-87, no?
70custom20 is offline   Reply With Quote
Old 12-15-2011, 07:21 PM   #10
nickacf7
Re: Frame ??
Thats a nice truck! Someday
