Old 12-20-2011, 12:07 AM   #1
56ClassicTruck
8.8 rearend help.
I have 2 explore 8.8 rearend I need help with to ID, I have the tag numbers first is a 93 -----s629E 3l73 88 3h11, ...
Second one is 94 s622D 327 88 4D14.....
anyone have any information on this rears, like gears?
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 12-20-2011, 01:32 AM   #2
fredscarryall
fredscarryall's Avatar
Re: 8.8 rearend help.
i put a 8.8 in my suburban. hope this gives you some help.in the 1993 the s629e= plant code. 3L73= 3.73 gear ration. the L in 3L73 is a traction loc which is fords limited slip rear end. 88=means 8.8 rear end. 3h11 is 3=1993 h=august 11 is the 11th day.in the 1994 s622d is another plant code. 327 is an open diff 3.27 axle ratio. 88 = 8.8 rear end. 4d14 is another date code 4=1994 d= april 14=14th day
fredscarryall is offline   Reply With Quote
Old 12-22-2011, 01:41 AM   #3
56ClassicTruck
Just what I needed, thank you..... fredscarryall......
1996 Dodge 3500 4x4
