12-30-2011, 03:28 PM | #1 |
SSN 706
Re: Not Another Rebuild Thread....
Where you trying to post porn? Because thats not allowed. Even large amount of bare skin are frowned upon. Really no ideas
12-30-2011, 04:04 PM | #2 | |
But now that you mention it, it was a rather large patch panel I am putting in I will try again laters I guess.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
12-30-2011, 05:34 PM | #3 |
Looks like I can post pics now so going to try this progress update again!!
#1 is my donor section and my problem area. #2 I started with cutting out the spot welds along the door jamb. #3 Then I taped off and cut out the minimum of the problem area. #4 I used the cut out problem area as a template, then holding the donor section up to the cab, I traced my cut lines again from the inside of the cab in a different color, and over size cut my patch. Then I slowly and incrementally trimmed the patch and the cab until the two fit up nice enough for me to start worrying about over doing it. #5 I think as I tack weld it in I will be able to get that gap closed even more that it is showing in the pic. I only had a couple of vice-clamps holding it in place for photos.
12-30-2011, 10:10 PM | #4 |
GMC's n H.D.'s too!
Looks much better now McMurphy!
12-30-2011, 11:39 PM | #5 |
That patch panel looks good. I know what you mean about trim a little, check it, trim , check it. It takes me so long to this kind of stuff. I know you will get it. Take your time and it will turn out perfect.
69 chevelle malibu, 64 C-10 shortbed |
12-31-2011, 01:13 AM | #6 | |
Well here is how it turned out... #1 after my initial pass on all my spot welding, I had to cut a half dozen of them on the back side on the long verticle seam because I was not paying attention and it mis-aligned on me. #2 this is how it sits now, ready for a light skim of filler, and paint. I also bonked myself because it wasnt until I took this pic that I even thought about the body lines aligning. Guess it is better to be lucky than smart, because I was HUGELY relieved to see they lined up as well as they did ! #3 this is my proud pic, this part looks so near seamless that I could lie and tell someone I know what I am doing ..... yah riiiiiiiight !!! #4 while I was running my spot welds on the patch panel, I was scooting over to the d-side and installing my fuel fill patch as well. #5 looks good to me !!
12-31-2011, 01:23 AM | #7 |
I think it is time for me to get the floor patches now that I feel more confident on what I am doing with the welder.
I know I will need both rear cab corners, both side floor pans and both rocker panels. I will probably order the complete rockers instead of the partials. I guess tomorrow will be a toss up between more fab work, or cutting out bad flooring..... I am certainly uncertain, at least I am pretty sure I am.... Good night all, beer time !!
