Old 01-18-2012, 11:59 AM   #1
mikesacs
mikesacs's Avatar
Mike's 60 Suburban build
A few month ago I found my next project vehicle. I thought I might as well start a record of the progress. It's a 1960 on a 1980 4x4 3/4 ton frame. Currently it has a 250 6cyl with a TH350.
mikesacs is offline   Reply With Quote
Old 01-18-2012, 12:17 PM   #2
burbluv
burbluv's Avatar
Re: Mike's 60 Suburban build
Very nice! Love seeing other 4x4's.
Welcome to the sickness,
AJ
burbluv is offline   Reply With Quote
Old 01-18-2012, 12:22 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Nice! Glad to see another '60 Burb on here! Look forward to your build.
Old 01-18-2012, 12:22 PM   #4
tazattitude
tazattitude's Avatar
Looks like a nice clean Suburban
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 01-18-2012, 12:39 PM   #5
1963c-10
1963c-10's Avatar
Nice looking truck. Looks like its in great shape.
1964 Short bed trailer
Old 01-18-2012, 01:16 PM   #6
mikesacs
mikesacs's Avatar
So far I've:
- sandblasted and had the rims powder coated
- new tires
- cleaned up the gauges inside and out, fixed the odometer
- changed the hood pods to 60 from 61s
- added a rear dome light housing in the back
- bought a bunch of parts to complete the truck
Old 01-18-2012, 01:46 PM   #7
padresag
then they must have shortened the frame as the wheels seem to be centred, beside a 3/4 ton would have been a longer w/b.
looks pretty clean
ron
padresag is offline   Reply With Quote
Old 01-18-2012, 02:22 PM   #8
mikesacs
mikesacs's Avatar
looks pretty clean
ron
Yes, the frame was spliced in 3 locations.
Old 01-18-2012, 03:01 PM   #9
Ledslinger
Your truck looks eerily like my 1961 GMC 4WD, same gray and similar patina. I think mine used to be Klondike Gold but when it was in a front end accident a later hood was installed and it was painted battleship gray. In its service as a university geology field camp vehicle it was known as the "Gray Ghost" A ghost it isn't.
Ledslinger is offline   Reply With Quote
Old 01-18-2012, 06:47 PM   #10
hopped up
hopped up's Avatar
very cool burb
hopped up is offline   Reply With Quote
Old 01-18-2012, 10:31 PM   #11
mikesacs
mikesacs's Avatar
I think this one started as Yukon Yellow (AKA school bus color). I assuming this since it's the oldest paint I can see. I don't know how to decode the trim number for a positive ID, if that's possible.
Old 01-19-2012, 02:47 PM   #12
mikesacs
mikesacs's Avatar
Spent a day under the burb with a wire brusk wheel on the floor boards. Wire brushed, wiped with thinner, and applied 2 coats of Eastwood Rust Encapsulator. The floor board are very solid. I could even see most of the red oxide factory primer. Did an additional coat of spray undercoating in the rear wheel wells.
Someday I'll do this again with the frame. It would have been too much to do in one day.
Old 01-22-2012, 10:37 PM   #13
mikesacs
mikesacs's Avatar
Disasymboled the doors panels today and painted the insides with the rust encapsulator. Used a paint brush taped to a 2' stick. Trimmed 6" off the stick whenever I painted what I could reach. Also polished the door latch mechanism where they slide when opening. This allowed the door latch open smoother with less effort.
Old 01-22-2012, 11:29 PM   #14
nbrfd007
nbrfd007's Avatar
Great job!!
nbrfd007 is offline   Reply With Quote
Old 01-30-2012, 09:15 AM   #15
mikesacs
mikesacs's Avatar
Installed some seat belts this weekend. I never liked the aftermarket seat belts that latch unless you pull them really slow and smooth.
I got these out of a 90 suburban's back seat. This is a parts vehicle that I have. They are the wrong color, but I thought if I could make them fit well then I'll search for some gray ones to match my interior. I used the latch part from the front seat since it was longer. The latch part still needs to be longer since it only reaches about 2 inches out of the seat crack.
I mounted the front edge flush to the door opening since if it was further forward it would restrict access to the back seat from the passengers side.
I wonder if these can still be bought new? I might try the Chevy dealer.
Old 01-30-2012, 12:11 PM   #16
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Looks good!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-30-2012, 12:54 PM   #17
padresag
looks like a custom body mount that you have there
ron
Old 01-30-2012, 01:43 PM   #18
mikesacs
mikesacs's Avatar
ron
It is a custom mount since it sets on a 1980 3/4 ton frame.
Old 01-30-2012, 03:40 PM   #19
padresag
here was some custom mounting on the 65 suburban that I got that was mounted on an 84 4 x 4 frame. the body is going on a 64 panel 4 x 4 frame
By rondavid at 2011-09-22
the fellow was pretty talented, but here is a lot of this **** that goes on in the name of building a truck
ron
Old 01-31-2012, 09:15 AM   #20
mikesacs
mikesacs's Avatar
One of my reasons for wanting a suburban was that I always wanted more leg room than what I could get in my 62 pickup. I took the drivers seat out of the burb and welded new mounting holes to the front of each seat bracket. This allowed me to move the seat back 1 1/4" back from stock. Worked great.
Old 03-07-2012, 01:32 PM   #21
mikesacs
mikesacs's Avatar
Pulled the 6.2L diesel out of the donor truck (the engine on the floor) and have removed the front clip from the 60 burb. I'll pull the engine shortly. I plan to paint the firewall the new body color before installing the diesel.
Old 03-19-2012, 08:06 AM   #22
mikesacs
mikesacs's Avatar
Painted the firewall. the pictures are; bare metal, primer, base coat, clear coat.
My firewall was originally silver, but I decided to go with body color. From reading this forum the consensus is that they could be either depending possibly on what factory they came from.
Old 03-22-2012, 12:23 PM   #23
Corts60
Just here to tinker
Corts60's Avatar
Coming along nice man. I like that you are going with the 6.2. I see good MPG in your future. I really like that color of green too!
Old 03-22-2012, 01:43 PM   #24
mikesacs
mikesacs's Avatar
I hope to get low 20's for MPG. I just bought the Banks turbo for it to install on the engine before it goes back in. The color was a tough choice. I think about 50% of the people will not like it! I just didn't want to go with a common color. It will be two tone with a white top. The paint line will be just below the side windows like a 62-66 two tone. I don't like the original 60-61 two tone line.[/I]
Old 03-22-2012, 09:36 PM   #25
mikesacs
mikesacs's Avatar
Painted the front frame, axle, and suspension with Eastwood rust encapsulator while I had easy access.
