View Poll Results: Which one should i do? | |||
EZ Wiring | 14 | 40.00% | |
Hot Rod Wiring | 1 | 2.86% | |
Painless Piring -Pickup | 18 | 51.43% | |
Painless Piring -Street Rod | 0 | 0% | |
A Member here has one for sale-+Contact info posted | 2 | 5.71% | |
Voters: 35. You may not vote on this poll |
01-23-2012, 04:14 PM | #26 |
Re: Complete rewiring
FYI. I just checked Rockauto and theirs is at $459.79 which is average, but still cheaper than buying it direct. They'll probably charge you shipping. If this is the kit you decide on, just search ebay #510089 and you'll find it for that price with free shipping.
01-23-2012, 04:18 PM | #27 |
AAW excellent quality and great instructions lead me to an easy weekend install.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
01-23-2012, 04:44 PM | #28 |
Unless you want to take it in the shorts *no pun intended* go with any company OTHER than Painful Products.
my $.02 |
01-23-2012, 06:10 PM | #29 |
My Spoon Is Too Big
485 after shipping
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
01-23-2012, 06:10 PM | #30 | |
My Spoon Is Too Big
458.15 on ebay + free shipping
01-23-2012, 06:12 PM | #31 |
LSX addict
another vote for AAW. i used the EZ, but i did alot of modification & an engine swap. if your just replacing it AAW all day long. i wish i would have went with them.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
01-23-2012, 06:17 PM | #32 |
My Spoon Is Too Big
yall have sold me on AAW.... Now Sell my wife on letting me buy it
01-23-2012, 07:58 PM | #33 |
Eat, Sleep, Drive a Chevy
I have used the EZ wiring harness and thought it was easy to do I really liked it due to all the wires being laser marked every foot or so there was no mix ups
I bought a Hot rod wires from a board member for my current truck. It looks nice but yet to be installed. Everyone says AAW is great, and by the replys you see here I would not be afraid to buy one of there kits Good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
01-23-2012, 09:20 PM | #34 |
i was going to rewire my 68 and was wondering if AAW is marked on the wires like EZ wiring is? thanks
01-23-2012, 09:48 PM | #35 |
Moderator
AAW is the closest thing you will find to NOS. It is identical in every way to the OEM harness. Plug and Play.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-23-2012, 10:08 PM | #36 |
BlahBlahBlah
Yes, I think that was my guy!
01-23-2012, 10:24 PM | #37 |
I did a search on this subject about a week ago after seeing the ez kit on Ebay for under $175. From the different posts I read everyone who used the ez kit was happy with it and felt it would have been unnecessary to spend 2-3x the money on a painless kit or something similar in that price range. I think maybe it might be something similar to buying a Monster hdmi cable for $100 when a no name $10 cable will perform just as well.
Posted via Mobile Device |
01-23-2012, 10:40 PM | #38 |
My thoughts:
I did AAW and it was easy...so easy I bought another kit for my crew. I read posts on how others bought a generic kit and were having issues getting the right terminals/fittings, etc. However, it was so easy I wonder if using a generic kit would be easy, too...especially after having already rewired with an AAW kit. Plus, having the original wiring harness to steal terminals from and cross check with makes it appealing to buy a generic kit to save some cash!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
01-24-2012, 01:31 AM | #39 | |
My Spoon Is Too Big
01-24-2012, 08:35 AM | #40 |
Quit if it's not FUN!!!
Only my $0.02 worth. Clear up some confusion first. Connector = the plastic housing. Terminal = the actual contact. My point: If you feel you have the skills, the E-Z harness has more than enough wire length to accommodate new (terminals), not to mention, it's a lot less $$$. The real objective is to replace all that 40 year old, brittle wiring. Most of the actual terminals are Packard 56 and can be found a lot of places. Mostly depends on the time and patience. I tend to be ANAL, so I spend way too much time on little stuff. I also take the time to install multi-pin disconnects on each major branch of circuits. I do this so I can mount the panel without wrestling all those bundles of wire. Mount the fuse panel, then run each major branch individually.
01-24-2012, 08:55 AM | #41 |
I think the extra $200 is well spent knowing that it's been done right the first time. Not that using anything less isn't, but the piece of mind knowing that everything is replaced with a new piece is there.
01-24-2012, 02:44 PM | #42 |
Regardless, you'll be using new terminals. The plastic housings don't matter so much. Having new wiring that isn't brittle is the "Plus"....less chance of shorts and in some cases less chance of fire.
Also, when you rewire you can run relays for the headlights, horn, etc... You'll get more "juice" to where you need it and have less chance of burnouts/fire/shorts, etc. It happens...
01-24-2012, 07:51 PM | #43 |
From what I have read it sounds like you have done all the hard stuff with lights, etc. If it was me I would get some good wire and terminals and update the engine compartment. Use the MadElectrical.com method and you will end up with a better system for upgrading, aftermarket accessories, brighter lights, etc. I can't remember if you have an internal regulated alt. but that works great with this system. You can't get stuff from them last I heard but look for good sxl wire (higher temp) and quality connectors and junction blocks from old GM stock that came on 70s-80s vehicles. The part # is 10098794 and you can find them in junk yards but they are only $2-3 bucks and I bought my dealer out a while back. I did this on my 72 3/4 ton and Camaro and it works great.
Larry 1972 Chevy C20 Custom Camper 1968 Chevy Camaro RS 1980 GMC K5 Sierra Classic |
01-24-2012, 08:01 PM | #44 | |
-steve
01-24-2012, 08:35 PM | #45 | |
Best of all it can be had for $388 from www.jegs.com. It actually took me more time to route the wires the way I wanted than to actually install the harness. I decided to re-wire my truck because of the old 40 plus years of the original wiring harness and to clean up all of the old hack job wiring done to it. Good luck! Keith |
01-26-2012, 05:27 PM | #46 |
So the AAW does NOT have the words lazered on it?
01-26-2012, 06:22 PM | #47 |
AAW DOES have the wires labeled all the way from fuse box to end. Here's a pic of the kit to give you an idea of what it looks like still in packages.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
01-27-2012, 01:33 AM | #48 |
yes, everything is labeled. instructions clear enough anyone should be able to install with minimal effort.
Mike Redpath |
01-27-2012, 03:28 AM | #49 |
Guest
Posts: n/a
AAW is plug and play PAinless is a PAIN you have to do alot of but connectors, Ive used Painless on a few projects that customers supplyed and I dont like them at all. The kit for a 76 ford F250 came with a huge pile of butt connectors and list of how to singally connect each wire to each single terminal of every switch in the truck. as well but splice all the light connections. I have the correct crimpers and correct brass terminals to have done it right using the factory plug housings.
AAW is WAYYYY better you wil think you bought a factory harness. also the wire that painless used for the blower motor on this particular ford was half the size of the factory and soon overheated hence I had to fix it right |
01-27-2012, 11:04 AM | #50 |
Tags |
circut, fuse, wiring |
