Old 01-20-2012, 02:08 PM   #1
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
More Dana 60 axle carnage:
Its official, I have now broken all four shafts in a Dana 60. The passenger stub shaft 4 times, passenger inner shaft once, the drivers stub shaft twice and the drivers inner shaft once. Last time out I broke one Warn premium hub and BOTH stub shafts. The pictures are of the drivers side and yes all those little pieces are chucks of axle. Most breakage has been stock axles but I also broke a Yukon big spine stub shaft last year.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 01-20-2012, 02:59 PM   #2
Burt4x4
Burt4x4's Avatar
Re: More Dana 60 axle carnage:
Dudde!!! Heavy Throttle?
No more johnnywagon, now yer johnnythrottle
Have a great weekend!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-20-2012, 07:13 PM   #3
txriverrat
That is impressive. My buddy has blown up a Dana 60, 70, and 80, but that's with a Cummins, not a gas engine.
What engine/trans/xfer case/gears are you running?
txriverrat is offline   Reply With Quote
Old 01-20-2012, 09:03 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
RPM Offroad Warn Drive gear upgrade. Problem solved.
Are your Yukon shafts Chromoly? 30 spline? 35 spline?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-25-2012, 12:46 AM   #5
johnnywagon
Chromoly 35 spline......at least it was. Truthfully the breakage there was on the ear by the u-joint.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-25-2012, 12:48 AM   #6
johnnywagon
Nothing special, Burt knows....its weight + heavy throttle + precarious terrain + boredom......
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-25-2012, 12:51 AM   #7
johnnywagon
I knew I was going to do some damage. I basically had the truck hanging on a shelf with all weight on the front and the rear dug into the soft side hill. There was so much pull on the front that the steering pegged all the way to the right and it would'nt steer at all. Just another day....
~John
71 Blazer One Ton
59 Belair 2 Door
