01-27-2012, 10:26 AM | #201 |
Re: Mesquite 1966 C10 - LS3 W/Air Ride
I'm having withdraw symptoms...need more pics.
01-27-2012, 10:58 AM | #202 |
I will post some this weekend. Headers should be here soon, that will allow progress to start up again.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
01-29-2012, 11:25 PM | #203 |
Went to gun shop for ammo came back with this. I think it's a nice touch
Posted via Mobile Device Posted via Mobile Device
01-29-2012, 11:31 PM | #204 |
Talked to guys at vintage air they said Corvette compressor would not work with their system. So up top it is, will be much easier to deal with.
01-29-2012, 11:38 PM | #205 |
Made some additional bends to the stock corvette power steering hose. I think I can get the hose modified at the 180deg bend and all will be good.
01-29-2012, 11:41 PM | #206 |
Transmission Cross Member is in but not drilled yet. Waiting for headers before I make final install.
01-29-2012, 11:45 PM | #207 |
Fuel Cell is in, brake lines are run.
01-29-2012, 11:47 PM | #208 |
Pressure gauge for fuel line, not sure it will work with engine covers but will be nice to have when I try to start thing thing up.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 Last edited by 66ChevyMax; 01-29-2012 at 11:56 PM. |
01-29-2012, 11:49 PM | #209 |
Got the Dakota Digital Gauges in, this system is cool.
01-29-2012, 11:51 PM | #210 |
Rollin' Old Skool
man, that's looking great...nice progress!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
01-29-2012, 11:53 PM | #211 |
This build will soon be in it's 4th month, if headers (from DT, thanks Shon) come in this week I can button a lot of things up and get closer to starting this thing. Chasis work is my favorite but I am really looking forward to sand blasting the bed and cab and seeing this thing in mock-up.
01-29-2012, 11:57 PM | #212 |
Is that the Kwik bracket set-up?
01-30-2012, 12:04 AM | #213 |
Yes, K10143. Requires a new belt, Gates K061005 (101 1/8")
01-30-2012, 12:44 AM | #214 |
Looking awesome. On your CPP motor mounts, are these the ones that say 67-72? I didn't see any for 63-66 but assume they are the same?
01-30-2012, 01:09 AM | #215 |
Yes that's correct
01-30-2012, 09:17 AM | #216 |
That's cool but those days are long gone here, If you ride around with that in the back window you won't be driving long and you will be on the national evening news. In MD even your water gun must be unloaded and locked seperate from the ammo ( the water )
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-30-2012, 10:47 AM | #217 | |
Build is looking great. Are you using all braided lines for fuel, or braided to hard lines?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-30-2012, 12:01 PM | #218 |
I'm going to start with braided and see how that goes. Some say the shop will always smell like gas if I use braided lines, we shall see.
01-30-2012, 05:44 PM | #219 |
trucks looking awesome, i love that gauge cluster!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
01-31-2012, 09:58 PM | #220 |
Well today was a big day, I finally have headers . Got the Doug Thorley Headers #323Y-C in yesterday and they still hit the CPP perch's called CPP and emailed them a photo, they said I had the adapter plates that move the motor 3" forward, so they sent me the one that only moved it 1 1/4" forward, all is good, still close but good.
01-31-2012, 10:03 PM | #221 |
Really pleased with these headers, thanks to Shon and DT.
01-31-2012, 10:03 PM | #222 |
Even the stock Dipstick works!
01-31-2012, 10:05 PM | #223 |
This is how the DT's look next to Sanderson LS10.
01-31-2012, 10:14 PM | #224 |
Rollin' Old Skool
sweet! before i scrolled down, i was thinking to myself that those headers look beefy...i've heard lots of good reviews about Sanderson, but those Thorley's look to be really well built as well...they look great, & i'm glad to see everything fits now
01-31-2012, 11:44 PM | #225 |
As always your work is great
Posted via Mobile Device |
