Old 01-31-2012, 12:21 PM   #1
cochino12
It followed me home?
cochino12's Avatar
spring hangers
Will 4wd rear leaf (rear leaf front hanger) spring hangers work on a 2wd? If so will it result in a lift or drop on stock suspendion?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-31-2012, 02:14 PM   #2
brad2
Re: spring hangers
Yes they will work and will give you about a two inch lift.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 01-31-2012, 11:57 PM   #3
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Re: spring hangers
I had the same idea the other day cochino. Also Bell tech makes a short rear shackle that is suppose to raise it up some.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 02-01-2012, 12:21 AM   #4
brad2
Re: spring hangers
I gave the wrong answer. I don't know about the front hanger. Look at the LMC catalog and you should be able to see if they are different.
74 swb
71 2wd Jimmy
82 2wd Blazer
