02-12-2012, 10:25 PM | #1 |
Re: 1981 Chevrolet C50 Pick-up Conversion
Another good day's work.
Got up and pulled the engine out of the truck. Degreased the engine and stripped it to the long block. Wire buffed the block. Tomorrow I will blast the intake, valve covers, timing cover and oil pan. I will also be blasting all pulleys and brackets. Will pick up new gaskets, plugs, wires cap and rotor tomorrow. Decided on Ford Blue for the engine, yes I know that may be a little blasphemous but I like the bright blue better. Now that the engine is out, I will be degreasing the inner frame rails, and other spots I missed on the front end. Then I will be hitting it with a high gloss black. I will also be prepping the firewall and changing the color to bright yellow. I hope to have most of this done during this week. I also ordered a pair of block hugger headers last night, hoping that works out...
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
