02-13-2012, 05:00 PM | #1 |
$$$million dollar oil pan "?"
Okay, so i have been doing quite a bit of research, losing whats left omy hair trying to figure out if i can replace my oil pan gasket w/o removing the motor.... I have a 1979 c20 w/ a 350 & 400 tranny. There appears to be enough room, but i dont want to start a 90 mon project and turn it into an all day job. Anyone know if this is possible?
Posted via Mobile Device |
02-13-2012, 05:49 PM | #2 |
In the Forgotten far North.
Re: $$$million dollar oil pan "?"
I did it on my old 74 c10. Just had to hand turn the crank a few times to get the pan to clear it as I removed/installed it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
02-13-2012, 06:39 PM | #3 |
Canadian Trucker
I've done several oil pans and have never run into any problems. But if a clearance problem arises, do like BLE' BURBAN said or at worst if you have an engine picker, just pull the engine mount bolts and lift the engine an inch or two. But it really shouldn't come to that.
2020 Silverado Trail Boss - 6.2/10spd |
02-13-2012, 08:12 PM | #4 |
i did it and jacked the engine about two inch like dalaigh said and it went pretty well
02-13-2012, 08:51 PM | #5 |
Robert Olson Transport
in the old days when i did this without a hoist id undo the motor mount bolts and jack up the motor from the oil pan with a floor jack with a piece of wood on it.. then id stick a couple of chunks of wood between the motor mount on the block and its perch on the frame to give it room and was able to redo the oil pan that way... always replaced the pump while i was at it too
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-13-2012, 09:00 PM | #6 | |
02-13-2012, 11:15 PM | #7 |
Thank you all very much for the quick replies. I appreciate teh experience and the advice. I feel well prepared for hopefully a quick turn around, and hopefully a fun weekend.
Hey any of you going to the winternationals here in Phoenix this weekend? Take care! Will |
02-14-2012, 11:15 AM | #8 |
78K & 79C Jimmys
yup lifting it up makes it easier
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-14-2012, 01:22 PM | #9 | |
02-14-2012, 01:39 PM | #10 |
Kid's Mechanic
Take the fan shroud lose first . A couple of short 2"x 2"s . Spend the extra money on the one piece silicone pan gasket , That's a gift from above . Just did this very thing a couple of months back in a c30 .
02-14-2012, 03:35 PM | #11 | |
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
02-18-2012, 11:54 PM | #12 |
So the project is done.... something special though. I found out that the block is a 4bolt main.... the inside of the pan was practically spotless, and the pistons were upgraded at some point! This thing is cherry inside the block. I am just really excited that it is a 4bolt main.....
Thank you all for your suggestions. The job went seamlessly, and i appreciate all of gour experience and expertise. Willy Posted via Mobile Device |
