#3426 |
67cheby
![]() Join Date: Sep 2008
Re: What did you do to your truck today!
Nice job on the kick panels
Posted via Mobile Device |
#3427 |
![]() Posted via Mobile Device |
#3428 |
Installed the 94 amp alt from an 86 silverado. Internally regulated, 3 wire set up. Fixed the amp gauge too.
[IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#3429 | |
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#3430 |
I installed the sound deadening insulation and started restoring the heater equiptment. I had several heaters and vent boxes to choose from so I could take the best parts of many. I sandblasted parts and applied rustmort over night. Paint it all tomorrow.
I know I can! I know i can! 72 K20 Restoration |
#3431 |
I have been upgrading my timing chain and sprockets. Its been a real pita. I've had the most problem out of the harmonic balancer installation tool than any of it. But we are almost done. Just fixing to check on the timing.
Bigdog ![]() |
#3432 |
![]() Join Date: Mar 2010
Thanks bro!
#3433 | |
I gotta do mine, thanks the inspiration |
#3434 |
Tinkered on the new C10 for a while today. Replaced the LOOOONG van-style oil filler tube with a oil cap / grommet, checked plugs / gaps, tested compression on all cylinders, and installed a squarebore carb to q-jet intake adapter (previous owner had installed edelbrock directly to the original intake). The old 350 still isn't running right, but it looks like the timing is WAY off. I think the previous owner dropped the distributor in without setting TDC on 1. It'll run, but the #1 wire has to be clear over past the normal #8 position, and the vacuum advance doesn't appear to be working well either. Probably going to hold off on any more troubleshooting until the new HEI shows up. Hopefully the new install will clear up all these little issues...
I also crawled underneath to check out the saddle tank setup. The tanks look great from underneath, but who knows what the inside looks like. The switch and saddle tank fuel lines are disconnected but all there if I decide to hook it back up. For now I might pull the new-ish tank out of my donor cab tomorrow and see how clean it is.
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
#3435 |
![]() Join Date: Mar 2011
Spent a great day hanging out with forum members JohnOro and V-Dog.
Oh, and we swapped out the water pump on my truck. ![]() Thank you for the help and conversation. It was much appreciated! |
#3436 |
Active Member
![]() Join Date: Mar 2005
Bought it and brought it home. after installing a new master cylinder and bleeding breaks. 1967
67 short step ![]() 71 Custom ![]() |
#3437 |
Nice! Congrats!
#3438 |
Installed heater and rest of insulation. Ordered the adapter for 72 gas pedal to fit earlier cab from member. Watched youtube video on installation of harness.Just ordered wiring harness from American Auto Wire on ebay. $479
#3439 |
I've got grease on my mind.
Turned my truck into this!
#3440 |
First off gorgeous truck, second, what is that hanging off the E-Brake release?
#3441 | |
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#3442 |
thought thats probably what it was, but almost looked like a yellow thong... So i had to ask!
#3443 |
Unplugged interior wire harness, I have a harness that has excellent fuse box writing and it has like new wires, very clean so replacing my old one. Removed dash and replaced the green turn signal and high beem red color caps with blue. Going with blue lghts in dash so thought why not blue turn signal and high beem. Used a blue plastic and cut out and glued on the cardboard supports in dash. Took dash pad in to get recovered in leather like my side panels are. Going to take a dremal and polish up fuse tabs in the fuse box before I install.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
#3444 |
Collector of Projects
I ddnt do anything to it... bit it sprung a leak on me... heater core.... damn.
#3445 |
![]() ![]() Still working on it Posted via Mobile Device |
#3446 |
#3447 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#3448 |
Same thing I do everyday Pinky, Jumped in her and went to work! Thought about washing it but decided it was pointless!
#3449 |
#3450 |
Put on my No Limit Shock relocators.
