Old 02-23-2012, 09:39 PM   #1
Number21
Number21's Avatar
Hub gaskets?
I took the driver side hub off my truck (Spicer, D44) and found both gaskets inside to be torn apart. Obviously I need replacements...where can I get them? I don't see them listed on any auto parts store website.
Can I use a bead of RTV instead?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 02-23-2012, 09:58 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hub gaskets?
It's been years, but I have found gaskets for my Warn hubs at the local NAPA store. Might be one of those small items that are in stock but too minor to be listed on the website. If you can't find any, RTV should work OK.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-23-2012, 10:42 PM   #3
CrewCab59
CrewCab59's Avatar
Re: Hub gaskets?
There was some gaskets and shims on ebay week ago, you can cut your own out of gasket sheet. If you plan on sealer use Right Stuff , it's the best sealer out there.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-23-2012, 10:45 PM   #4
Number21
Number21's Avatar
Re: Hub gaskets?
Found some on ebay but I don't want to wait that long. Will sealer work in place of the metal gasket/shim?
Old 02-25-2012, 01:46 AM   #5
Number21
Number21's Avatar
Re: Hub gaskets?
Anyone? I'm sure it would be ok to replace the paper gasket...but the metal one?
Old 02-25-2012, 12:23 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hub gaskets?
Morning bump for ya
- Mike -
RIP El Jay
Old 02-25-2012, 12:38 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Hub gaskets?
I've taken apart a bunch of these old Spicers and its not uncommon to find the metel shim missing..but the fact that it is a shim and not a gasket it should be replaced with such. I'm not going to say you cant get by with out it, but if your trying to do the job right then order a set and put them in at a later date.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
