Old 09-10-2003, 06:31 PM   #1
Tink
Tink's Avatar
Gas Tank Size?
I've got a 76 Cheyanne. When I took apart the dash, somehow the gas guage got screwed up. I know I get about 10mpg but need to know how big the gas tank is to know how many miles I can safely go on a tank... So, how do I tell what size the gas tank is (other than running it to empty)?
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-10-2003, 06:54 PM   #2
bagged78
world class smart ass!
bagged78's Avatar
Well you have two choices,
1. 25 gallon
2. 31 gallon
I have each one, and the only differance that I can see is when looking at the tank from the rear of the Blazer the 25 gal. seems to be level ( by level I meen from the flat piece that sticks out from the middle of the tank down to the bottom) and the 31 gal. seems to have a slight taper.. That may or may not be acurate but it is what I can see, and ever one that sells gas tanks lists them as 25 and 31 gallon tanks, and no other options..
Hope this helps, I guess you could assume that your tank is only 25 gallons and if you have a 31 gallon you would be safe....
Aric
75 2WD BLAZER (never ending project)
-some day maybe-
02 2500HD CREW CAB 4X (daily drive)
-8" lift 37s and 22s-
____ ____________________________
bagged78 is offline   Reply With Quote
Old 09-10-2003, 10:28 PM   #3
bagged74
its just $$$$$
bagged74's Avatar
I beleive that is an accurate description in the difference. You could also just run it low and fill up, and see how much it holds.
bagged74 is offline   Reply With Quote
Old 09-16-2003, 10:26 AM   #4
CRRoy71
So, would this one be a 31. My sticker in the glove box says that it has the 31 gal, but I have let it get pretty low and I have never put more than about 25 gal in it. Maybe my gauge is a little off?
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 09-18-2003, 10:31 AM   #5
CRRoy71
any ideas?
Chris
