02-15-2012, 07:14 PM | #101 |
Re: 67' C10 Build V8 Conversion & 700r4 trans
It warmed up a little, to 40 degrees.
Here Is a picture of the trans. and a Picture of the Wheels & wheel cap, I also included a shot of the Sanderson Headers they are ceramic coated
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, |
02-15-2012, 07:16 PM | #102 |
67cheby
hmmmm....invisible trans and wheels !!
02-15-2012, 07:17 PM | #103 |
just about to say that! i think he got the hover conversion from back to the future.... and he doesnt need the transmission if he has a flux compacitor LOL
02-15-2012, 07:18 PM | #104 |
67cheby
OH YA...now that is more like it !! WOW ,looks great
02-15-2012, 09:27 PM | #105 |
thats nice.........
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-16-2012, 12:17 AM | #106 |
Yea I like the wheels,
You can see the reflection of the wood ceiling in one of the spokes on the wheel
02-16-2012, 07:29 PM | #107 |
Did not do very much today.
Cleaned the front half of the frame some more. Just when you think It's pretty good, It aint. Cleaned and de-greased the frame some moe today. No-body wants to see a pic on that. Looks like I will be on frame clean up for another day or two, until I can get it clean enough for paint. I also replaced the Fuel Line coming off the bottom of the Cab/Gas Tank, to the ridged line that rides inside the frame to the engine. That Old fuel line was very soft. I had about 5 gallons left in the tank, and I did not get any on my face or eye or accidentally drink any fuel, or end up wearing a few gallons. This was a good day It went smooth, Nice.
02-16-2012, 09:42 PM | #108 | |
heres one i was doing that today myself no high jack seem like we r on the same schedule u got more newer part$ looks great just thought id throw in the frame pic for laughs hope u dont mind been following your progress
jz Quote:
02-17-2012, 01:15 AM | #109 |
Hey Zicc1835,
Frame looks good are you also using the KBS coating? I will show some pics while I am doing the 4 part process on the Frame. I am hoping that I will be able to start the painting process tomorrow, but I need to make sure that the frame is extremely clean, so that it will accept the paint.
02-17-2012, 01:43 AM | #110 |
no I dont know what i am using yet was leaning towards the POR my frame only looks good cause it was wet in that picture i picked this up in Long Island PO said was a Texas truck lots of pitting on frame and i already replaced inner and outer rockers cab corner and kick panel repairs ....i wanted it cause of the 402 700r4 and cheyenne package tilt tack speed buzzer ...air
02-17-2012, 10:26 PM | #111 |
I have used POR-15 on a couple of other projects (2ea. Porsche 914's) it worked, i used it on the floor panels.
I have another 914, hopefully soon to get a 350 h.p. Chevy 350ci V8, and a 5sd manual trans, mid engine, and all up weight is 2200-lbs w/ V8 installed. Our trucks weigh 3400-lbs. TRUCK 3400lbs. / 350h.p. = 9.71 LBS per Horsepower (under 10 Lbs. per H.P. is good) 71' 914 PORSCHE 2200lbs. / 350h.p. = 6.28 LBS per Horsepower, 350h.p.@ 5300rpm & 415 lb per ft torque @3700rpm, 4 wheel disc brakes stock, uses Regular Gas Mid engine for balance (Insurance not too bad) (6 LBS per H.P. MUCH BETTER) 2012 Z06 Corvette 505 H.P. 427c.i. engine, Weight 3200lbs Premium gas Only, 3200Lbs / 505H.P. = 6.33 Lbs per H.P. Oh Yea $75K (Insurance is terrible $$$$$)
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-17-2012 at 10:41 PM. |
02-18-2012, 11:55 AM | #112 |
Nice progress! keep it up, wheels look super nice! you're working way too fast and making me look bad. seriously though, great work man. You'll be done in no time.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-22-2012, 10:36 PM | #113 |
From the pics below you can see the white chalky look on the frame, this part of the etching process, and rust protection, The next two processes add the color (Satin Black)
I am still waiting for a 60 degree day to paint the frame. I also need a 60 degree day to get the Heater Core Fiberglass Cover painted Black I was checking the mounting of the Brake Booster. Here are a couple of pics.
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-22-2012 at 10:48 PM. |
02-23-2012, 01:22 AM | #114 |
VA72C10
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. |
02-23-2012, 09:54 PM | #115 |
I will have to take a picture tomorrow.
Today, I cut a 2ea. 4.00" hole's in the drive shaft cross member, then welded in a 4.00 diameter x .125wall thickness tubing, into the hole for support. This will be my exhaust route for my lowered truck. I decided to get this taken care of first, then paint my frame tomorrow. Temp should be about 60 degrees and low moisture tomorrow. A good day to paint. Hopefully.
02-24-2012, 11:08 PM | #116 |
It's tomorrow,
Here's a picture
02-24-2012, 11:09 PM | #117 |
Started painting the frame
The Frame looks much better and this is only 1st coat of #3, Like new even. I still have another coat of #3 and two coats of #4 Here are a few pictures
1967 Chevy C10 Lwb I6-250ci 3spd manual trans Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar, Last edited by westgl; 02-24-2012 at 11:14 PM. |
02-24-2012, 11:11 PM | #118 |
Here is a shot of the steering BEFORE.
and a shot of a couple of NEW Arms
02-25-2012, 10:54 AM | #119 |
67cheby
looking very nice !
02-25-2012, 12:49 PM | #120 |
Hello I westgl Icome from quebec canada and I am very interested in your project I did a truck like yours but have SEVERAL spend winter in the salt and snow I t, sends a link of my pick-up http://vieuxpick-up.forumactif.com/t...chevy-c10-1967
02-25-2012, 07:59 PM | #121 |
Nice project rejeandem,
Thanks 67cheby, it is coming along. Still need to finish the frame Paint. Once I get the parts back from the powder painter which should be this coming week. I will be able to start putting the front end back together.
02-25-2012, 11:53 PM | #122 |
frame looks great nice progress
02-26-2012, 01:44 AM | #123 |
02-26-2012, 07:57 PM | #124 |
Thanks Guys,
I hope to have the frame done soon, but it was 32 degrees today. Not a Good paint day so i have to wait.
02-26-2012, 08:02 PM | #125 |
I need to make a Spacer Plate, and a Backing Plate, for the power steering pump.
This will beef up the frame, around the Power Steering pump area, so that the frame will not crack, or be damaged.
