#126 | |
Re: Project truck dream 65"
The inner post or hinge is 2 piece,so you can leave the end in the visor that clips into the hook. Good idea to take some 400 grit to clean any rust on your old mounts, paint,then slide the later visors back on .You may have to trim the visor ends and re-upholster if you raise them up like I did. Check for the hook location by.... looking at visor in up and visor in down position as well and then how it best lines up with your body lines on the roof. Position the hooks where they best suite you,mark through the hole with a pencil and drill.Be aware there is a locating nib at the top of the hook,you will need to drill for that as well. If you still need pics,let me know. Cheers, Ed ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
#127 | |
Cheers, Ed ![]()
#128 |
Found a great product that is a butyl based insulation/sound deadner,most of this stuff is asphalt based which I didn't want,so away I went with the install.
Best to do this in a warm shop,for moister reasons and workability.Probably went overboard on areas above the floor,but that's something I wont have to question later on. Not a bad idea to have some extra heat in the cab at the time your doing this,it does help.This material is 60mil thick so when cold,its tough to work with ! I went to the top of the firewall and back up the rear cab wall.I dont know that Ill bother with the kick panels,maybe later . Make sure that if you choose to torture yourself by doing this job,meditate for at least one day!! Make sure your floor etc.is clean,that you get the air bubbles out and seal all joints with metal tape.Use a small roller,upholstery or heavy industrial type scissors,they work well. Sort of looks like the inside of the space shuttle ? I'm sending my resume to NASA.
#129 |
What is the brand name?
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#130 |
The name of the matt,is b-quiet ultimate.
Cheers, Ed.
#131 |
Guessing the 12 sq ft gave you enough materiel to do the whole cab with some left over?
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#132 | |
Cheers, Ed ![]()
#133 |
![]() Join Date: May 2009
Over and above the call of duty on your rust issues, great job nice to see quality work done I'm subscribed! Like the dash extension it looks like it belongs there and I will be watching as you finish your truck for more ideas like the tank fill very cool...Vernski
#134 | |
The last the letters in your user name? Are you Polish by chance ? Cheers, Ed ![]()
#135 |
Hi back at ya from Roger,just got back from his place.
Send him an email and ask him about the 65' he's building. Cheers, Ed ![]()
#136 |
#137 | |
Cheers, Ed. ![]()
#138 |
So in the past few days I got a real wake up call.Now believe me when I say this......,I did my homework to find the best replacement parts and this is what I went through .
Aftermarket inner fenders and rad support........, now because of liability concerns,I will not mention brand however I can assure you these are the quality line,I couldn't imagine worse ! I know better at my age not to expect new panels to fit properly without a little work,but this was pathetic. After reading a thread by another member who lives close by,we determined his and my parts are the same manufacturer.At that time I decided to send my junk back to the supplier. Fortunately I stopped in the middle of my assembly and did not try to make any mod's to my parts,(at least nothing obvious ![]() Hope you all appreciate the pics on this as much as I did at the finish of the assembly. First 2 pics are passenger side fit at the corner and twist in the rad support that lifted it off the frame mounts.Now keep in mind these bolts are all finger tight !! 3rd pic is of the rad support from the side,look at that lean...just like I had a head on into a retaining wall.Keep in mind folks,these are new panels. The last pic is the drivers inner from underneath looking up.In order to get the passenger side inner bolted on I had the remove all the bolts here at the drivers side...., and this......, Is how the holes lined up there with all 3 pieces together. The moral of the story is....unless you want to spend days on new sheet metal repairs,Id look hard for repairable oem parts. If you need a second opinion..see below link as well. http://67-72chevytrucks.com/vboard/s...ht=repo+fender Cheers, Ed ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 Last edited by lenguini; 03-14-2012 at 06:03 PM. Reason: spell |
#139 |
I do believe sir that all the rad supports I have seen photographed lean inwards 1 to 3/4" at the top. There was quite a discussion on someone else more recent thread as well.
I have not mocked my all original body parts back up to check this, but that lean does seem to be intentional, or in the least a common design (flaw?)..... I did not realize that I had not read your entire thread before today. Awesome work you have done here. Is your build timeline the same as your posting? If so you are just jamming along!! Though I understand you have experience, help, tools, equipment, and probably time up on me ![]() Your dash is looking super nice too, I dig your mods! Thanks for the sq-ft info on the deadner, I would never have guessed you could use 50sqft inside a single truck cab like that..... Also glad you mentioned the boxing in of your frame rear for tank protection. I am going to give mine a second look now too when I get back to that end of the rig..... Keep it coming, I am digging this.
#140 | |
![]() Quote:
My build started a year and a half ago,so I'm not moving anywhere near the speed it appears to be. ![]() Thanks for the complement's they keep me motivated ! Cheers, Ed ![]()
#141 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
#142 | |
Oh Gosh.....,Gee whiz...,Im special !.....................getting lost for ...words....getting ...misty.. need... kleenex...... Thank you very much ![]()
#143 |
Active Member
![]() Join Date: Aug 2011
Wow... Nice to see you saved this relic. Great metalwork..I don't think I would have had the patience to replace all the rust. Lots of great ideas here too. I hope you don't mind if I use a few when I get around to my builds. I'm particularly fond of the dash extension and the gas filler in the stake pocket.
Subscribed and will be watching the progress. Keep the pictures coming. You're doing great work!!
Fleet '66 ***************** '66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade '64 C-10 LWB BBW near future project - "The Wife's Ride" '58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show |
#144 |
That had to be a painful excercise in futility..
It pi$$es me off just looking at it. Good call to bail out on it when ya did and jes go OE.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#145 | |
Ed. ![]()
#146 | |
![]() Cheers, Ed.
#147 |
Why hello there !Guess what folks,I got rid of the inner fender and rad support junk as I said I would.
I bolted the oem parts on .....,and everything lined up fist try !It was a little tough bolting on all the old crusty stuff,bit I quickly got over that ! I have taken pics that I felt explained themselves.Compare fitment to the junk I returned,no contest here ! Nice even spacing either side looking down the front of the truck,and notice the rad mount to inner fender fit when bolted finger tight ! Also for comparison is the up underneath pic drivers side. Some work to be done on the used stuff,but a fraction of what it had taken on the new. Thanks to all of you who participated in helping me with this stage of my build.A'lot of time and grief has been saved because of it. I toast to honor all of you ! ![]()
#148 |
Urgh,finding that the new fenders aren't fitting so well once the nose/grill support was bolted on......,more aftermarket junk.
Guess I'm going with oem outer fenders,that took all of 1 second to decide. I borrowed the red primed inners in the pics,mine should be here tonight or tom,I found some sitting in a warehouse off a California truck. That will be some good news when they get here,rust free and no dents.I paid pretty close to the same as the junk new ones that I just sent back. I guess it would have been cool to have new sheet metal on the truck,but at what cost? I go out of my way to by North American products because I just cant stand the idea of our own out of a job,this junk was a good slap in the face reminder to stay on that path ! "SHAME ON ME " ! I really hate bolting any part on this truck that wasn't made in the US,I never owned a vehicle made overseas and never will,so why bolt the junk on and disgrace my Chevy with it! ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 Last edited by lenguini; 03-19-2012 at 09:43 PM. Reason: spell |
#149 |
You sir, are obviously not French-Canadian...
Not that there is anything wrong with our Canadian neighbors, French or otherwise, just a different ahhhhhhhh mind set, shall we say? Must be a French thing.... ![]()
#150 | |
![]() Great folks both sides of the imaginary line from east to west, and I have had the pleasure of meeting many. That makes me a lucky and well seasoned character,so I'v been told ! ![]() Cheers, Ed.
