Old 01-11-2012, 08:12 PM   #1
6 Door King
Chevy version of the Ford High Boy?
I have found a Chevy that the owner swears is a factory lifted truck, claiming it is Chevy's version of the High Boy. It's a 79 4x4, but that's about all I know about it. Just curious if anyone has heard of this "package" or if the owner is blowing smoke? Any details you could share would be appreciated, and maybe I'll learn something!
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 01-11-2012, 09:55 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Chevy version of the Ford High Boy?
I don't know of any chevy truck coming lifted from the factory. Its all aftermarket. I say he is blowing smoke. Heres a question, does it matter? The only reason to have a factory lifted truck is for it to be covered under or not to void the warranty.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-11-2012, 11:52 PM   #3
6 Door King
I had never heard of anything like what he was describing, it was just obscure enough to get me thinking though. I was imagining the heavy half package and the other oddball stuff Chevy turned out over the years. I figured if anyone would know it would be you guys. I dug around on the web and drew blanks everywhere but I knew you gearheads might have an old sales brochure or picture of just such a vehicle. If anybody has any more info I would love to know about it, just to expand my knowledge base.
Old 01-12-2012, 12:13 AM   #4
coops714x4
coops714x4's Avatar
A F^*% "high boy" I thought that was a old rodder trick of setting the body on top of the frame of a old coupe ??? but I don't give a crap about a F$(% , I would say hes blowing smoke, if it was factory the spid would show it
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 01-12-2012, 12:37 AM   #5
snj8198
snj8198's Avatar
When I purchased my '79 Scottsdale Sport shorty from the original owner he said it came from the factory with with roughly a 2" taller suspension. It had a few amenities like tac, aluminum faced bezel, a neat little hood emblem and captains chairs. I don't know for sure, just what he said.
Name:  1979 Chevy 001.jpg
This was the original paint and wheels. I had Weiand 177 on a built small block so I had the new hood built when this pic was snapped. 6" lift in this pic.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-12-2012, 09:54 PM   #6
ghettoluxury
ghettoluxury's Avatar
He is correct I have a set of factory 2" lift springs in the barn. Gm used negative arched springs and the factory lift springs have a positive arch in them.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-14-2012, 10:25 AM   #7
I don't know of any such thing. A Ford Highboy is a '77 and earlier F250,so Ford didn't even make them in '79. When they were tall they were 4" tall,not 2". They were still using divorced transfer case/transmission design. When GM 4wds had divorced transfer cases they sat up like Fords.
Old 01-14-2012, 10:35 AM   #8
Mike C
Mike C's Avatar
I'll bite, both of you guys with factory lift springs, what is the SPID code? If they were factory installed they will have a #.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-14-2012, 10:46 AM   #9
1970ChevyC-10
I know GMC had a truck called a High Sierra that was made in the late 70s and early 80s that came stock with a small lift
1970ChevyC-10 is offline   Reply With Quote
Old 01-14-2012, 11:29 AM   #10
snj8198
snj8198's Avatar
This truck is long gone.
Steve
Old 01-14-2012, 01:22 PM   #11
High Sierra was a trim level,just Like Custom Deluxe. High Sierra is what they referred to as way up in the Sierra Nevada mountain range. High Sierras could be 2wd or 2wd and it had nothing to do with suspension.
The Fords that people started calling "Highboys" once the lower '78s came out were not an option. It's just the way "all" the trucks were designed. The fact that Ford started making their trucks lower shows the trend to make 4wds more user friendly and comfortable for the new widespread customer base of the 4wd market. '78 was also the first year for the full-size Bronco which took them away from the Jeep market and into the Blazer and Ramcharger/Trailduster market. I highly doubt (and certainly don't remember) GM took off in the opposite direction. It was a time when style and ride comfort was taking over,which is why negative arched elliptical springs were the standard,which makes vehicles ride lower.
Old 01-14-2012, 07:45 PM   #12
milled
milled's Avatar
id say he knows his stuff!
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 01-15-2012, 02:31 AM   #13
Zane M
I have absolutely no idea, but my guess is he is either blowing smoke, or it was possibly a dealer lift.
Zane M is offline   Reply With Quote
Old 01-15-2012, 12:34 PM   #14
Your41Plague12
Your41Plague12's Avatar
It was probably an aftermarket kit installed by a dealer, not by GM. GM never did this from the factory. The Ford "Highboys" were made from '67-77.5. They were only made through half of 1977. They had 4" blocks in the back and positive arched springs in the front. Easiest way to tell a true one is looking for a divorced transfer case setup and a gas tank in the cab (filler is on the cab itself). Anyway, GM never did this and I'm guessing it was just for user-friendliness. Those old Fords look mean though! I'll definitely own one some day.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-15-2012, 01:29 PM   #15
No,I've been around long enough to fake it pretty good,that's all..heh heh
Around '79 it was pretty common for a dealer to trick out trucks because the 4wd thing was exploding wide open. There was a local Ford dealership called Big Henry's that put out what they called The Sandbox Edition. They were short Flaresides with a graphic paint scheme,chrome roll bar/push bar,lifted,and 36" Mudders/10" chrome spokes. I think they did some long Stylesides,too come to think of it. I had my home brewed '69 Power Wagon back then and had fun watching those pretty trucks get all broken up by guys with more money than sense. If I broke an axle,that was my truck payment for the month...they had two payments that month There's started off all pretty and got beat up.Mine started up beat up and got pretty...er
Old 03-13-2012, 02:11 AM   #16
66 4x4
Like said all 67-77.5 ford F250s 4x4 are nicknamed "Highboys" by owners. It is not a Ford term. They are not a option at all, all 250s 4x4s in that year range sit at the same hight. There was not a highboy or non highboy option. I have had 3 of them and still have a 77.5 non highboy. lol
66 4x4 is offline   Reply With Quote
Old 03-13-2012, 08:45 AM   #17
Oh yeah,one of those Medium Boys. I remember that option
Old 03-13-2012, 11:25 AM   #18
1972RedNeck
1972RedNeck's Avatar
'66 and older Chevy trucks had a block under the rear like the fords. All F250 4X4's before '77.5 had a block under the rear. It was just 3" on the pre '67 instead of 4" like on the '67 - '77.5.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 03-14-2012, 09:30 AM   #19
Chevy version of Ford Highboy:
Old 03-18-2012, 11:19 PM   #20
63chevyll
gets board easy.......
63chevyll's Avatar
I had. 79 std cab 1 ton dually 4x4 that sat very high.
I loved how that rode and how high It was
63chevyll is offline   Reply With Quote
Old 03-19-2012, 12:49 AM   #21
Dooley
Dooley's Avatar
My 1980, 1979, 1977, and 1988 4x4 duallies all measured about the same. I had ordered 7.50-16's on all but the 1988 which came with 235/85's. The 1977 helper springpack had 6 leafs while the others had 5.
Dooley is offline   Reply With Quote
Old 03-19-2012, 10:14 PM   #22
willett
Another Day, Another Dollar
willett's Avatar
I think that your bang on.
After some quick research it looks like the ford highboys were sitting on a taller frame than the post 77.5's. Nothing really do do with anything other than the foundation.
I could be incorrect though......
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-22-2012, 10:49 AM   #23
Your41Plague12
Frames were the same, as far as I know. They used higher arched front springs and a 4" block for the rear, as well as a divorced 205 setup.
Steve
Old 03-22-2012, 08:35 PM   #24
71veronica
71veronica's Avatar
i want all of those duallys
71veronica is offline   Reply With Quote
Old 03-22-2012, 08:45 PM   #25
From what I noticed on the earlier set-ups,they put a cross member for the shackles up front that you can see below the bumper. It seems to compensate for the rise in the frame,which creates a lift,and they used blocks in the back to level it up. I'm not familiar with frame changes on Fords. But,you don't see that cross member on 78/79s which have the same body and bumper.
