03-25-2012, 09:35 PM | #1 |
Still Learning
Original Bucket seats installation????
I'm trying to drill the holes in my cab for original bucket seats. I'm looking for some pictures of the braces and alignment of the seats. Anyone document their installation? I have the material to make the braces but would kinda like to see some originals.
Are the outside front holes used on LH and RH seat mounts? Thanks |
03-25-2012, 10:30 PM | #2 |
Still Learning
Re: Original Bucket seats installation????
Here are some pictures of what I'm looking at.
Notice that the seats are touching the center console on the sides with the bolts in the outer stock bench seat holes. |
03-25-2012, 10:37 PM | #3 |
subscribed. Always thought they used the same holes as the bench seat - so, therefore, I have no clue.
03-25-2012, 10:45 PM | #4 |
Still Learning
I have always thought that too but, it just doesn't look right. The driver side inside mount hits the tranny tunnel raised area before the bolt will fit in the hole too. I can force it in there but it's tight.
03-25-2012, 11:07 PM | #5 |
if you look there are dimples in non bucket seat floors for bucket seat location. There are also dimples in the center floor pan for the console as well. The only direct bolt in is the the buddy bucket seats, all others must be drilled to fit.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
03-25-2012, 11:19 PM | #6 |
I don't have my cab here to confirm this, but it appears that the dimples refered to are visible in a couple of your pictures outboard of the seat brackets. Looks like 1/2"-3/4" out from the existing holes. This is consistent with where my original buckets were mounted from the factory.
03-25-2012, 11:37 PM | #7 | |
Still Learning
Any chance any of you experts have some pictures of your original buckets or a measurement from the seat bracket to the center edge of the radius? |
03-25-2012, 11:39 PM | #8 | |
Still Learning
These look like dimples in the picture here:
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 03-25-2012 at 11:45 PM. |
03-26-2012, 12:08 AM | #9 |
Those are the ones I was referring to. I don't have any pictures that would help, and the truck is currently disassembled and 2000 miles away. If you can wait about 3 weeks I can get pics. However, I estimate the seats are about 3/8"-1/2" away from the console. I have some shots with the seats installed but from a 45 degree angle... not much help.
03-26-2012, 12:20 AM | #10 | |
Still Learning
03-26-2012, 12:56 AM | #11 |
I found this old thread http://67-72chevytrucks.com/vboard/s...d.php?t=352079
Perhaps post 8 will help. I'm still searching for others. Jim |
03-26-2012, 01:37 AM | #12 |
Here's another thread http://67-72chevytrucks.com/vboard/s...d.php?t=367549
03-26-2012, 04:53 AM | #13 |
Always on the hunt...
Hi Mike, I have owned decent share of these trucks over the years and done a few 69-72 truck bench to bucket conversions in them years and have not came across any floor pans having the dimples already in place for drilling the bucket seat mounting bolt holes, maybe that was a regional/plant type of deal. I'll give this a shot to the best of my knowledge, when using the 69-72 truck bucket bracket setups and when going into an original bench seat truck cab, there is only one hole of the eight in the bench cab floor pan that's already in the correct place and that you are going to use when bolting the bucket mounts in. The one bolt hole (only one in correct location) that you should use is the RH fwd. most outer bolt hole, so it would be the pass. side fixed mounted bucket fwd. RH bolt, you will need to drill the other eleven mounting bolt holes. I have had these pictures of an OE option #A50 bucket seat floor pan that were taken for another member and then stuck away in a saved folder, not sure if they will help you dimensionally as they don't have any measurements but the pics do highlight all twelve of the bucket seat bracket mounting bolt holes and they also show how the factory used pan head filler screws to plug the other bench seat mounting bolt holes. The bottom view pictures highlight the factory added bucket seat cab only floor cross support & extra bracing. Hope this post and pics can get ya headed in the right direction, Mel.
03-26-2012, 04:57 AM | #14 |
Last five B/S floor pan pics...
03-26-2012, 08:26 AM | #15 | |
Still Learning
Thank you so much. This is exactly the information I was looking for. What you are saying is my pass. side holes I already drilled are in the right position. I only used the outer front hole and then marked the other three with it bolted down in that one hole. I'm assuming the driver side mount setup is wider becaus the outer holes need to go outward about 3/4-1" in your picture. Do you happen to know what the gap was at the center console between the seats on both sides? Also, when you installed these buckets on bench trucks did you fabricate that front brace that runs across the bottom of the rib at the front mounting position? thanks for the help. |
03-26-2012, 09:38 AM | #16 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-27-2012, 12:33 AM | #17 |
Still Learning
Okay, I bit the bullet and went with Mel's suggestion from the original bucket seat floor pan. Although I didn't build the brace that ties the two sides together I did make some braces from some old ball bearing drawer slides. They are the exact thickness and near the same width and depth. Here are the pictures of what I did in case someone else can use it. If you look at the pictures, you'll notice I moved the driver side hole pattern outward 3/4". this made the two seats the same distance from the edge of the seat to the door opening symetrical. It also made it where the driver side seat isn't bound up against the console.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 03-27-2012 at 12:43 AM. |
03-27-2012, 12:35 AM | #18 |
Still Learning
More pictures
03-27-2012, 01:09 AM | #19 |
very helpful - thanks for posting (everyone) - answers some questions I've had for a while also.
The pics are worth a thousand words, as they say... |
03-27-2012, 02:06 AM | #20 |
70+ ( Old Skool Club )
Another great post to keep seeing I'm 90% sure I'm getting buckets and console for Pinky.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-27-2012, 07:57 AM | #21 |
67-72 parts collector,…
Great work on the underside reinforcements!
03-27-2012, 08:48 AM | #22 |
Still Learning
Thanks Keith.
Thanks to all you guys the helped me figure this out. That's the stuff that makes this board great |
03-27-2012, 01:15 PM | #23 | |
03-27-2012, 02:30 PM | #24 |
Great thread!!! Been looking for this info layed out like this for a long time. Im wondering if there would be a market for a kit that would supply the tabs, cross support, and paper template for the conversion???? I dont have the manufacturing capability to make the parts (press brakes are way to cheap) but if someone does maybe might be an opportunity.
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
03-27-2012, 04:21 PM | #25 |
Still plays with trucks
Nice work Mike. Very clean.
I would add a cross support similar to stock. I am concerned the center of the floor isn't designed for the load of the central seat mounts and would stretch out or crack over time if left unsupported.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
