#26 |
Still Learning
Re: Original Bucket seats installation????
You really think it's necessary or just extra insurance? That rib that runs across the front is pretty stiff just by design. I would like to fab one up, I have already thrown a bunch of time at this though. I will look at it tonight.
#27 |
Always on the hunt...
![]() Join Date: Sep 2006
Hey Mike, judging by your pics, you are already well above and beyond the under side bracing found on most of the bucket converted truck cabs that I have seen. What about the question I had asked you in post #23? Mel
#28 | |
SWB 4x4 Collector
![]() Join Date: Jun 2001
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#29 |
Eat, Sleep, Drive a Chevy
nice work Mike
I am going to keep this one for future refrence
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#30 |
I will add that the big middle brace can be found and removed from any early blazer, got mine from teeitup. Randy usually cuts them out when he parts out a blazer. If you get this piece you can use it as a template to drill the front holes in the correct location and then either use panel adhesive or weld it in. This piece really takes all the guess work out of where the holes should be.
Jeff Posted via Mobile Device
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#31 | |
SWB 4x4 Collector
#32 |
Man of Mini-Talents
Hey Mike,
On mine, I used the outside front holes and then marked the locations with a Sharpie so I would have the locations exactly right with these seats. In the process of drilling I noticed the dimples that others have seen. Anyway, I went ahead and used the outside fronts as they would be more secure than what I rigged up, and the console just barely touches the seats at the front corners. Not snug at all. *shrug*
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#33 |
NICE work mcbassin!
project: "my happy mess" |
#34 |
Just like to part out trucks!!
Trevor, Ron is coming up here Wed evening, I'll make climb under this BB truck of mine and see the front bracket, that way he can tell Roger
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#35 | |
Still Learning
About that question, no there were no dimples for the seat, however there were dimples that lined up good on the consoles. They were almost like the center punch marks you see on the high hump covers. |
#36 | ||||
Still Learning
Thanks. |
#37 | |
Still plays with trucks
You would think if buckets would work safely without it the factory would have left the floor pans alone and not added the bracing to it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#38 |
Laid Back
![]() Join Date: Apr 2010
Looks good mike!! I think you have more than enough bracing!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#39 |
Man of Mini-Talents
Start spinning off some sets Mike. The line forms behind me, guys.
#40 | |
![]() Join Date: Sep 2009
Always appreciate you Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
#41 |
I'll take a set once you have them. Thanks, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#42 | |
As per my PM (thought I would post so everyone would get the answer): Time frame you are looking at for the next batch? Did you guys reproduce the big bracket or all the small ones or both? Thanks,
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#43 |
Subscribed...I'm gonna need this info too
#44 | |
SWB 4x4 Collector
Original Poster- I am sorry for straying away from your intended thread. You did a wonderful job with your brackets, and your work looks really clean and has a factory type quality. Trevor
#45 | |
We could make it in several pieces and weld it together but a used part from a Blazer would be less expensive. We are looking into an alternate method of bracing the front seat mount points. What we have in mind would be quick & easy with inexpensive materials that could be installed by anybody who can install a rocker panel.
#46 | ||
Still Learning
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 03-29-2012 at 11:52 PM. |
#47 |
![]() Join Date: Oct 2009
I am interested in a set of braces as well if/when you get around to making some more Duncan and Son. What a great thread - thanks mcbassin
#48 |
pics !!!!
72 Cheyenne Super 80 Silverado Blazer 2wd |
#49 |
Excellent
#50 | |
It is the center mounts at the front near the cutout for the high hump tunnel cover as they are as far as you can get from a structural member. Lots of span makes for lots of flex under load. These two are the ones to worry about.
