03-22-2012, 10:08 PM | #1 |
'86 K35 parting out
'86 K35 for parts. Ex-Ontario Hydro truck. "Should" be 4.56 front and rear, according to paperwork that came with the truck. Transfercase/adapter NOT for sale. Should be cab and chassis frame/rear diff.
Snowplow, Northman 8 foot blade, working when pulled, $300 for everything you pull, $500 I pull Running Targetmaster 350, $200 you pull, $400 I pull Working TH400 tranny, $200 Driveshafts $75 each if good Front Dana 60 $1000 (not inspected yet) Rear 14 bolt, $500 (not inspected yet) 5 cab roof lights, $50 Grill and trim and bezels, $75 Column, non tilt, with key, $65 Doors, good bottom seam from a quick look, $100/pair Mirrors and mirror arms, $50 Front bumper, $65 6 rims, $120 Tires, all 6 for $180, front two are like new, back 4 are in good shape Anything else please ask Motor can be heard running, truck is still driveable tonight (no brakes, use e-brake pedal ) |
03-23-2012, 08:49 AM | #2 |
Re: '86 K35 parting out
Look over the doors a little better and let me no how good they are if you wouldn't mind. If they are real good I will take them.
03-23-2012, 08:54 AM | #3 |
why you gotta be so far away ?
03-23-2012, 08:56 AM | #4 |
Do you have GMC Cab corners on this truck?
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
03-24-2012, 07:19 PM | #5 |
I don't know, but both are rotten. Sorry.
03-24-2012, 07:20 PM | #6 |
Pics of RH rims for madcow75:
03-24-2012, 07:21 PM | #7 |
RH door pics for madcow75:
03-24-2012, 07:22 PM | #8 |
LH rims:
03-24-2012, 07:23 PM | #9 |
LH door:
03-24-2012, 09:21 PM | #10 |
The rear steel wheels for sure. The doors are kind of hard to tell in the pictures. They are GM doors and not aftermarket? There are no seam swelling/rusting. If not I will take them.
03-25-2012, 12:10 AM | #11 | |
Doors I doubt are GM, I can never keep straight the difference in the front door seam between GM and aftermarket. I THINK the OEM doors had a flat seam, and aftermarket had a pinched seam. That's why I tried to show you the front door seam. Either way, I don't see any swell, just some light rust around the drain holes. Thanks! |
03-25-2012, 12:12 AM | #12 |
03-25-2012, 09:42 AM | #13 |
I think I will be going for a drive up there in 2 weeks april 7th or 8th which is a Saturday or a Sunday. I will take the wheels then if thats okay with you. I will pass on the doors thou since they are not OEM doors. Are you going to be cutting that cab up, is it scrap. If so I am still looking for a patch panel cutout around the rear of the cab by the rear window. Basically where the rear cab trim would go.
04-01-2012, 09:15 PM | #14 |
Top- Let the raping begin!!!
Cab lights, rubbers, screws and harness $50 (harness has been cut where it goes into the dash) |
04-07-2012, 09:22 PM | #15 |
Bump for axles. Both diffs are 4.56 open carrier. Gears appear to be in great shape, no rust, low mileage, oil is nice and clean.
