Closed Thread
Old 04-07-2012, 04:13 PM   #3801
bollybib
bollybib's Avatar
Re: What did you do to your truck today!
I installed a lights on warning buzzer.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 04-07-2012, 04:37 PM   #3802
aventur1
aventur1's Avatar
bollybib
So do you wire to chime then to lights?
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 04-07-2012, 04:46 PM   #3803
JHT67
JHT67's Avatar
Put on my temp historical tag and insurance, so now I'm legal, then off to the grocery store for a short cruise.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline
Old 04-07-2012, 04:48 PM   #3804
Mrcustom
Cool Re: What did you do to your truck today!
Got it installed, Finishing up all the little things
Mrcustom is offline
Old 04-07-2012, 06:52 PM   #3805
jrdv
jrdv's Avatar
Test fit some smoothies I bought from a board member.
They aren't going on this truck, but I wanted to see what they looked like.
They will be going on the red GMC one of these days! Just waiting on a 4/6 drop and some other goodies.
It looks like I need a taller wider tire for the back. I guess a 275/45/20 will have to work since the rims are 8.5" wide.
jrdv is offline
Old 04-07-2012, 09:34 PM   #3806
67cheby
67cheby
67cheby's Avatar
Looks great !
67cheby is offline
Old 04-07-2012, 10:33 PM   #3807
jjtackleberry
jjtackleberry's Avatar
Installed new bumper, and tag light.
Working on tach dash and new exhaust
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline
Old 04-07-2012, 10:52 PM   #3808
Shortnwide4x4
Shortnwide4x4's Avatar
I installed this leather seat from a late model burban.
Shortnwide4x4 is offline
Old 04-07-2012, 11:17 PM   #3809
Pont406
My dailly driver blew a headgasket so was driving c10 as a dailly driver. Today I took it to my friend's chassis dyno and did some tuning on it. Best pull was 332hp and 360 torque at the wheels.
Pont406 is offline
Old 04-08-2012, 12:29 AM   #3810
JointTech
JointTech's Avatar
removed the insulation under the dash. spent 4 hours scraping most of the black goo they used to stick it down. Note to self. The insulation is not fire retardant... I got sick of scraping and was going to heat up the insulation and goo with a blow torch. Started a little fire....
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline
Old 04-08-2012, 01:39 AM   #3811
UNEASYRIDER
UNEASYRIDER's Avatar
Installed new bumper and grill
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 04-08-2012, 02:04 AM   #3812
KY Colonel
KY Colonel's Avatar
Had a high beam out so I installed new headlights. I haven't done anything with the wiring but thought I'd try silverstar headlights anyway...HUGE difference!!!
1970 K20 Custom 427/TH400/PS/PB and a dash of badass!
I was made in America, my truck was too...4 years before me.
KY Colonel is offline
Old 04-08-2012, 01:04 PM   #3813
Hotrob72
Hotrob72's Avatar
New pinion seal
New U-joints & carrier bearing (had it balanced as well)
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 04-08-2012, 06:34 PM   #3814
wrwelton
wrwelton's Avatar
Well the windshield is in the truck. Had as guy come over and put it in for me. Some things are better left to the professionals. I bought a sliding window a couple of years ago ata aswap meet for the truck and went to put it in and come to find out it is for a 73 chevy. You can not trust everyone. I have seen a couple since but knew I had one already. Well the search continues. I will try to find an original aluminum one or I will buy new. Bummer. Should be starting it this week.Any one looking for a 73 aluminum slider let me know.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 04-08-2012, 06:36 PM   #3815
wrwelton
wrwelton's Avatar
looks a lot like mine. good score.
wrwelton is offline
Old 04-08-2012, 08:37 PM   #3816
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
so are those the front from a bench seat 'burb..... or the second row seats from it or a Tahoe?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 04-08-2012, 09:50 PM   #3817
mud.man.rj
mud.man.rj's Avatar
Finished one side of my truck and started on the other side, removed door and bottom hinge and ready to cut and lower improperly installed rocker, welded on 1" too high same as the other side. Nice install but just too high.
mud.man.rj is offline
Old 04-08-2012, 10:09 PM   #3818
KY Colonel
KY Colonel's Avatar
Changed my oil.
Floored it and gave my stomach butterflies lol
Old 04-08-2012, 11:00 PM   #3819
Shortnwide4x4
I was told it was one of the rear seats from a burban. It was not a direct bolt in!! A couple hours worth of time but it fits pretty well. The contour of the seat matches with the 4wd and 4spd shifter, and now I gots cup holders!!
It's a much nicer ride than the factory seat too.
Old 04-08-2012, 11:34 PM   #3820
ItsRandy
ItsRandy's Avatar
Got my last door (driver's side) bolted back on and adjusted, what a pain in the a$$. It's a OEM door, just not the original door. It fits pretty good, just not as good as the passenger side door which is original. I also got my air conditioning condenser mounted in the radiator support and installed new lower radiator mount brackets.
ItsRandy is offline
Old 04-08-2012, 11:40 PM   #3821
jhwkns
Registered Cruiser
jhwkns's Avatar
My old trusty fuel pump gave up Friday after many faithful years of reliable service. It was born in the spring of '98 on the East side of Las Vegas. It spent it's entire life dutifully working on a '69 Chevy C-10 outlasting two engines, and countless other parts, too many to mention. All was fine until that fateful day when with an enormous eruption of motor oil and gasoline that it announced it's demise. It is survived by among many other components it's closest friends, The Carburetor, and The Fuel Tank to both of which it was closely attached. There was a private service in the garage after which the remains were recycled.
Because of all of the fuel that polluted my motor oil I had to change it also. Last Fall my A/C compressor seized. Tucker Parts where I purchased the kit replaced it on the spot without any questions. I've always received great service from them. I wasn't in any hurry to install it with months of cool weather ahead, but with temperatures in the ninety's expected next week the time was ripe to put my air conditioning back together. When I was lubing the truck I found a bad outer tie rod end, and replaced it as well, and also put new bushings on my sway bar. Many of the parts I replaced nearly fifteen years ago are really starting to show their age. Some of these have a whole lot of miles on them. They don't last forever, but it all proves what an incredibly reliable truck these are.
I intend to live forever. So far, so good.
jhwkns is offline
Old 04-08-2012, 11:45 PM   #3822
trkfrk
trkfrk's Avatar
I primed my bed in prep for paint.......
And the Easter Bunny came last night when I finished....
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline
Old 04-08-2012, 11:46 PM   #3823
allchevy58
allchevy58's Avatar
Drove the GMC to work three days last week. Today, washed a couple of trucks, took some pictures and put them down for the night.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 04-09-2012, 10:20 AM   #3824
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Finished up the GMC frame swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=518599
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline
Old 04-09-2012, 01:01 PM   #3825
72peace
72peace's Avatar
Took the metal bed off in prep for the wood. It looks like I've got some rust work on the cab too.
72peace is offline
Closed Thread
