Old 04-05-2012, 06:11 AM   #101
xpickup
xpickup's Avatar
Re: 48 panel truck
mud.man.rj, Thank you. I always like to save a buck. Then I can buy more parts.
oldman3, This time, don't worry I have done plenty of dumb things.
Shannon
xpickup is offline   Reply With Quote
Old 04-05-2012, 10:15 PM   #102
mud.man.rj
mud.man.rj's Avatar
Re: 48 panel truck
Having a good thinker is a big saver, fab skills sure make a difference plus then your build is not like everyone elses.
mud.man.rj is offline   Reply With Quote
Old 04-05-2012, 10:30 PM   #103
PRWFAB
PRWFAB's Avatar
Re: 48 panel truck
AMEN MUD MAN I like to look at other peoples stuff and tweek it into what I'm doing not just copy it.
PRWFAB is offline   Reply With Quote
Old 04-05-2012, 10:36 PM   #104
mud.man.rj
mud.man.rj's Avatar
Re: 48 panel truck
Ya me too, I build other project mostly year round and have to make them all a bit different to make them extra cool and fit the owner too. Have to really sit back and think some times, even come up with a lot of cool stuff when dreaming at night, yep a bit obsessive, nothing like hotrodding, it's a life style.
Old 04-06-2012, 08:55 PM   #105
xpickup
xpickup's Avatar
Re: 48 panel truck
I worked 6 hrs at work this morning. We had off but we are so busy so that I worked some. Then came home and finished up the back brakes. The only thing I have to do now is change the residual valve to a 2 pound one and bleed the brakes. I have the emergency cables mounted but have to mount my pedal and figure out where to route the cables. Then the brakes will be totally done. It will feel good to have them done. I should soon be able to put it back down on the ground soon. Then the wipers and some metal work around the windshield and cowl vent. I filled it already but do not like the way I did it , so like so many other things I will redo it to my liking now. I hate redoing things!
Old 04-06-2012, 11:26 PM   #106
oldman3
oldman3's Avatar
Re: 48 panel truck
Shannon, looks good. What's the width and back spacing on your wheels?.....Jim
oldman3 is offline   Reply With Quote
Old 04-07-2012, 09:40 AM   #107
AUSSIE54
AUSSIE54's Avatar
Re: 48 panel truck
Shannon, nice job on the brakes mate and good close up on the wheels. What size rubber are they?
Happy Easter also. As we'd discussed I have just done the egg thing, chewed the ends off the carrots that the tin lids had left out and then ran a trail of Easter Bunny poo (jelly beans) from room to room with a nice cluster at the front door from where his journey had started. They should love it!
Trently.
AUSSIE54 is offline   Reply With Quote
Old 04-16-2012, 09:07 PM   #108
xpickup
xpickup's Avatar
Re: 48 panel truck
oldman3,AUSSIE54, sorry I keep forgetting to check the wheels and tires for you. I will tomorrow.
It seems like I have not posted for a while. I made a tool for the air chisel to contour the belt line. I have to round it a bit more but it does work for the small dents. I then made the dolly of the profile of the outside of the belt line. I made it on a bridgeport mill with a ball nose end mill. Then blended it on the belt sander. I tried it out on a sample piece of belt line I made. I hit it with a hammer to put a dent in then took it out with my new tool. I have a small area to fix on my panel where I welded the new bent line to the old and it pulled in a little bit. So hopefully it will fix it.
Shannon
Old 04-16-2012, 09:10 PM   #109
xpickup
xpickup's Avatar
Re: 48 panel truck
Next was the emergency brake that I worked on. I had a pedal and cable laying around so I used it. I bought the lokar rear ones for the new disc brakes. So I made mounts for the pedal and made new mounts for the cables too. I welded them to the boxed area on the inside of the frame. It worked out great, now I have to bleed the brakes yet.
Shannon
Old 04-16-2012, 09:14 PM   #110
xpickup
xpickup's Avatar
Re: 48 panel truck
forgot the pictures.
Shannon
Old 04-16-2012, 09:30 PM   #111
xpickup
xpickup's Avatar
Re: 48 panel truck
Next was the wipers. And what a pain in the A$$. I bought the Its A Snap ones a couple of years ago, and if I had it to do over I would used the factory ones and used the Blazer rear hatch motor and went that route. I will have to make custom defroster vents because that is where the wiper transmissions are. I wanted them to work like the factory ones do, so one had to be mounted one way and the other the opposite way. I cheated and used poly line instead of the aluminum tube for the bends and the area tying the transmissions together. I just made stub pieces to go into it. I mounted the motor in the passenger side lower cowl. I think I have to change the stroke on them but at least they go back and forth. I used the factory outside pieces so the angle of the wipers was right. I cut off the the end and then drilled out the hole on a lathe so the new wiper transmission would go into it. Then had to shorten it up about 3/8 of a inch. They are 54 ones. That was one of the many thing I got rid of years ago that I should not have! I also bought aluminum wiper arms also.
Shannon
Old 04-16-2012, 09:31 PM   #112
xpickup
xpickup's Avatar
Re: 48 panel truck
a few more.
Shannon
Old 04-16-2012, 11:04 PM   #113
Fat Mike
Fat Mike's Avatar
Re: 48 panel truck
You make the coolest tools. Looks good!
Fat Mike is offline   Reply With Quote
Old 04-16-2012, 11:22 PM   #114
oldman3
oldman3's Avatar
Re: 48 panel truck
Shannon, always like you updates, seems you always have made a new tool or some way to hook up things. Nice work as usual.....Jim
Old 04-17-2012, 07:13 AM   #115
xpickup
xpickup's Avatar
Re: 48 panel truck
Fat Mike, oldman3, Thank you. I like to make the tools to make things easier.
Shannon
Old 04-17-2012, 09:19 AM   #116
99 to Life
99 to Life's Avatar
Re: 48 panel truck
luuuuuuv that beltline tool you made. You should seriously make and sell those. Not everyone has access to a machine shop, so it would be much harder for them to make something like that.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-17-2012, 09:28 AM   #117
xpickup
xpickup's Avatar
Re: 48 panel truck
99 to Life, Thank you. The only bad thing is you could not use them on much except a panel truck. You probably could not use it on the doors without cutting a access hole and the back of the cab is all closed up too. It would work on the cowl though.
Shannon
Old 04-17-2012, 10:31 AM   #118
AUSSIE54
AUSSIE54's Avatar
Re: 48 panel truck
Great work as usual there Shannon! Looks like you had a big weekend too!
Trently.
Old 04-17-2012, 08:48 PM   #119
xpickup
xpickup's Avatar
Re: 48 panel truck
oldman3, AUSSIE54, They are 20 inchers in the back and they either 8 or 8.5 wide with a 4 inch back space. The tires are 255/35ZR20.
Shannon
Old 04-17-2012, 10:23 PM   #120
oldman3
oldman3's Avatar
Re: 48 panel truck
Thanks Shannon......Jim
Old 04-22-2012, 07:24 PM   #121
xpickup
xpickup's Avatar
Re: 48 panel truck
I now have the wipers finished now and removed them so that I could redo some metal work that I did. I now have the metal work all done around the windshield now and I am beginning the filler work now. I made a new cowl vent filler. I did it in two pieces and I put my belt line dies in the bead roller and did a 1/2 up in them, then needed to bend it up a little. I then welded to two pieces together. It was easier than trying to get a good edge at the belt line. I had a few other pieces that I need in the belt line. So I just ran some off and cut it out of that. I also had my little helper for a couple hours today. He loved getting dirty but his mom did not.
Shannon
Old 04-22-2012, 07:25 PM   #122
xpickup
xpickup's Avatar
Re: 48 panel truck
a few more.
Shannon
Old 04-22-2012, 09:30 PM   #123
oldman3
oldman3's Avatar
Re: 48 panel truck
Shannon, nice repair work, looks good. Tell Mom it's not the first time for getting dirty and it won't be the last....Jim
Old 04-22-2012, 11:23 PM   #124
mud.man.rj
mud.man.rj's Avatar
Re: 48 panel truck
Dirty boy that one, haha. Boy must be nice to have him out there with you helping, cool for you both, learning and bonding.
Old 04-23-2012, 12:01 AM   #125
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 48 panel truck
Great work as always. Just goes to prove that being inventive and having an imagination can take you very far.
Kabwe is offline   Reply With Quote
