02-29-2012, 11:18 PM | #51 |
Chevy Enthusiast
Re: 540 BBC 68 Burb Dually 54" Boggers on Rocks
Sweet burb! I guess part of the dually fender on the passenger side will open up with the door? While your at it why not round off the openings to match the front fenders a little more?
I love me some ice cold Colorado Kool Aid!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
03-02-2012, 12:21 AM | #52 | |
With the rear passenger dually, it extends into the passender rear door. Just now it will go. Further onto the door. The problem is that it will cover up the door lock/handle so i guess i will buy a set of door poppers and shave the rear door and use a popper for the passenger doors since it comes in a set of 2. Ill still keep my driver door with the handle just incase there were to be a malfunction with the poppers ect. Let me know what ya think! Posted via Mobile Device |
03-06-2012, 01:41 AM | #53 |
Chevy Enthusiast
Sounds good, cant wait to see it!
03-16-2012, 03:34 PM | #54 |
Southern Nevada Coal Roller
What dually fenders are you using. I really want a dually burb. Your lines are killer
Chris Posted via Mobile Device
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins |
04-04-2012, 02:07 PM | #55 | |
As a side note I’m looking to sell the IFS/dana 60 8 lug dually set up as well as the wheels and tires that was on the truck prior to the rockwells. I only say that because you said you wanted a dually suburban Ill pm ya if your interested! And oh yea thanks for the complement |
04-09-2012, 03:05 AM | #56 |
Just a Member
sweet thread!!!!!!!!!!!!!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
04-24-2012, 10:28 AM | #57 |
Picture updates soon to come!!!
04-24-2012, 01:29 PM | #58 |
Nice progress.
Personally, I liked the slammed street dually, but originality and custom definitely dominate this build.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
04-24-2012, 01:56 PM | #59 |
great work! - subscribed
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-25-2012, 10:40 AM | #60 |
Haha thanks man, yea to each his own i guess. Theres going to be a lot of people that think it is stupid or gaudy yadda yadda which is fine to me as long as they recognize and appreciate the fab work that went into it thats all i can ask for!
04-25-2012, 10:41 AM | #61 |
04-25-2012, 10:47 AM | #62 |
So ive been meaning to post some more up to date pics but they were all on my phone. I get bad about not taking pics during the work cause i just get cought up in what im doing and documenting it is just an after thought. So heres where im at right now....
1. Clipped the drip pan off the sides and tach welded the roof down. 2. Replaced the rocker box on the drivers side. 3. Lots of little body work here and there filling gaps n such. 4. Building a tube frame chassis. All 2" .120 wall DOM tubing. |
04-25-2012, 10:51 AM | #63 |
Drip pan before clip
04-25-2012, 10:55 AM | #64 |
back side sorry about lighting
04-25-2012, 10:58 AM | #65 |
Driver Side applying some mud...
04-25-2012, 10:59 AM | #66 |
Rear of drivers side after sanding.
04-25-2012, 11:06 AM | #67 |
So in order to start building my tube frame chassis i needed a flat, level, and even surface in order to make sure the tube was all 100% square. So one of my friends has a shop where im going to build the chassis so i had to transport my old chassis and tires as well as material to his house...
04-25-2012, 11:10 AM | #68 |
Just tooling around pics with my helpers. Dude in the red shirt owns Mad Hatter Customs, does some legit work and sends a good bit of stuff off to SEMA every year. Old hippy guy with the white shirt is the owner of the shop who is graciously letting me using his space!
04-25-2012, 11:15 AM | #69 |
Ah now for the chassis design stuff, i just started on saturday so its goin kinda slow but heres where im at as of last night 4/24/12, almost have one half done. An incredible amount of knotching and a huge learning curve!!! Not to mention that at 7 bucks a foot very expensive mistakes!
04-25-2012, 11:19 AM | #70 |
Just more tubing pics. Last pic is a tube knotching software program called tube miter. Allows you to make accurate copes by entering the size of the materials being knotched together and angle... pretty sweet if your a cheap skate and dont want to shell out the cash for a trick tools knotcher!
04-25-2012, 11:23 AM | #71 |
More poser tubing pics... The last 2 pics are at 11 hours of fab work.
04-25-2012, 11:28 AM | #72 |
Day 2. end pic is at 21 hours...
04-25-2012, 11:31 AM | #73 |
oops not that end pic this end pic is at 21 hours! haha
04-25-2012, 11:33 AM | #74 |
Just welding on some cheap pipe to make sure the gaps from the knotched copes would be able to be welded with out warping the material real bad...
04-25-2012, 12:29 PM | #75 |
Chevy Enthusiast
Insane work man!
Tags |
54" boggers, big block, dually, monster truck, suburban |
