04-29-2012, 01:33 PM | #1 |
Re: 540 BBC 68 Burb Dually 54" Boggers on Rocks
04-29-2012, 01:43 PM | #2 |
Started on the other side of the chassis...
04-29-2012, 01:45 PM | #3 |
Just a wide view pic.... Trying to make there mirror exacts once the chassis are done i will tie them together and start to build my motor and body mounts ect
04-29-2012, 02:04 PM | #4 |
Amazing.... simply amazing.
04-29-2012, 02:19 PM | #5 |
Thank you for the kind words sir. Im only 26 so theres a huge learning curve cause this is the first time ive ever taken on somthing like this....
Any advice from members like you is greatly appreciated (execpt for your small block theory!). A huge majority of the individuals on this forum are light years ahead of me with a wealth of knowlege that i would love and be honored to tap into as my build progresses... thanks again man Posted via Mobile Device |
05-03-2012, 11:29 AM | #6 |
Just getting the center part of the chassis together... still trying to make sure everything lines up.
05-13-2012, 06:06 PM | #7 |
Chassis almost done!!!! Time to pull the bottom one off and tack the chassis to the table to make sure its all level and get ready for full weld.
Tags |
54" boggers, big block, dually, monster truck, suburban |
