Old 05-08-2012, 10:08 AM   #1
2wd73blazer
Starting a CCSB build and advice needed
My daughter is turning 16 this month and for some reason she expects a car. Imagine that. I dont want 2 car payments so I decided to sell my new crew cab and fix up a old crew as I get the time and money so I can buy her something nice. Here are a few pics of what I'm starting with. I contacted Ebfabman and he is going to shorten the frame for me. As for the suspension I havent decided whether I want to go 1/2 ton or keep it 1 ton. I do know that I want to lower it and it will probably be a static drop. Has anyone lowered a 1 ton? If so are the parts readily available?
2wd73blazer is offline   Reply With Quote
Old 05-08-2012, 10:14 AM   #2
2wd73blazer
Re: Starting a CCSB build and advice needed
Does anyone know how much is taken out of the frame? I want to run dual fuel tanks and was wondering if I am going to have to change the rear springs from the long ones to the shorter ones so the tanks will fit. It looks like I have about 24" between the rear of the cab and the front spring hanger on the rear.
Old 05-08-2012, 05:20 PM   #3
Cherub
Cherub's Avatar
This link will start you where you need to be. if not just start throwing some thing in the search function and you might find what your looking for.
Cheers
Cherub is offline   Reply With Quote
Old 05-08-2012, 05:45 PM   #4
rs72z
rs72z's Avatar
You will remove 14" starting about a 1 1/2" behind the front bed bolt hole. You can measure back from the rear cabmount to make sure you get the same distance on both sides. You also will need to take 3 1/2" off of the rear.
You can stay with dual tanks but you will have to change to the 16 gallon tanks to make them work.
Check out some of the build threads that are on here.
Looks like a nice truck to start with.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 05-08-2012, 06:37 PM   #5
SCOTI
SCOTI's Avatar
Agreed, nice starting point.....
3/4 & 1-ton drop spindles were available from Bell Tech, Western Chassis, & DJM. Start your search there.
The 16 gal tanks are the 1/2 ton short bed tanks & should be easy enough to source.
Removing leafs, flip kit, & an air-over-leaf set-up will drop the rear or you could opt to remove the leafs altogether for RideTechs HD rear 4-bar set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-08-2012, 07:54 PM   #6
2wd73blazer
I bought shortbed fuel tanks and sending units for a 87 since I want to run efi. I also have a perfect shortbed with dual tank doors and 91 Suburban front clip. Just waiting on Ebfabman to finish his current customer. I am next in line.
Old 12-01-2012, 09:25 AM   #7
2wd73blazer
Took my truck to Eb yesterday. I cant wait to get it back. He does amazing work. I will post pics of the frame after he cuts it.
Old 12-01-2012, 10:15 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Remember Early Classic Enterprises sell a 3/4-ton to 1/2-ton conversion spindle for the front.
These ECE spindles allow you to run all the same balljoints and tie rod ends,... but the spindle accepts a 1/2-ton rotor and caliper.
I know your truck is a 1-ton,... but the balljoints are the same as the 3/4-ton trucks.
Makes the front swap to 1/2-ton simple.
Keith
Convert to disc brakes.
Old 12-01-2012, 11:24 AM   #9
LEEVON
LEEVON's Avatar
That was a good move! I haven't seen Eb on here in awhile, looking forward to some pics of his awesome fab work!
You'd be waaay ahead to find a donor truck with 1/2 ton running gear and swap it over in my opinion. There is 1 ton lowering stuff, but it's limited.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-29-2018, 01:42 PM   #10
2wd73blazer
6 yrs later and she is off to New Creations in NC to get ls swapped and lowered.
Old 04-29-2018, 04:38 PM   #11
LT7A
Cool! Looks like you done some stuff since your last post, ha.
Old 05-07-2018, 09:41 PM   #12
2wd73blazer
New Creations is getting it done. My goal was to do it myself but life decided I wouldnt. Either way im glad to see progress.
Old 05-08-2018, 09:42 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks like its going to be a nice one. Keep us posted on your progress.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-20-2018, 10:00 AM   #14
2wd73blazer
A little more progress.
