Old 05-14-2012, 01:30 AM   #1
YBNORML
YBNORML's Avatar
Need help Identifying this transmission.
A couple of years ago I took this transmission out of an Astro van. I do not believe that it was the original transmission. The van was heavily modified with a V-8 conversion. The transmission was "supposedly" re-built with corvette internals. I am not sure whether or not that is true, however I did get the chance to drive the van before taking it apart and the trans worked well.
Can anyone help me narrow down the year of production and provide any other details on the tranny?
I'll post some better pics tomorrow.
The plan is to install it in my Blazer behind an early 80's 350. I Found this link http://transmissioncenter.net/700R4_Swap_Info.htm. The install seems pretty simple. I have never dealt with this style of transmission before, what is the plug with the three wires for? I think it is for the T.C. Lock-up. What is the Lock-up for and do I need it?
Anyways here are some pics I took of the transmission, plus one of the Blazer it's going into
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 05-14-2012, 08:19 PM   #2
clinebarger
Re: Need help Identifying this transmission.
Its a 87-93 700R4, GM calls them a 4L60.
The plug is for the TCC, It Needs to function.
The "Vette" 700R4 is not that different..."093" 2nd piston, Different 3-4 shift valve, & different governor calibration/diamond shaped weights.
Its imperative that the TV valve cable is set correctly.
Search this forum for lock-up & TV valve set-up.
I instinctively roll my eyes when I hear the term "Vette"
clinebarger is offline   Reply With Quote
Old 05-15-2012, 12:21 AM   #3
YBNORML
YBNORML's Avatar
Thanks for the response. I completely agree with you in regards to the "corvette " claims.
I am new to this style of transmission. I understand how imperative it is for the TV cable to be set up properly. You said the plug is for the TCC, what does that stand for? And what exactly does it do?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 05-15-2012, 06:55 PM   #4
clinebarger
TCC stands for Torque Converter Clutch.
Some threads on the subject...
http://67-72chevytrucks.com/vboard/s...highlight=lock
Old 05-16-2012, 12:01 AM   #5
YBNORML
YBNORML's Avatar
Thanks for the info and links. They will be a great help.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 05-16-2012, 12:25 PM   #6
61K10
61K10's Avatar
isn't a 700r and a 4l60 different as the 4l60 takes some kind of controller? there is a 4l60e thats maybe i am talking about. if it's a 700r you can also use a non lockup conv.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-16-2012, 12:53 PM   #7
storm9c1
*** That's interesting ***
storm9c1's Avatar
GM renamed the 700R4 to 4L60 in an effort to standardize their naming conventions across all transmission models. Then the 4L60E came along later, which is the electronic version.
If I recall, the convention decodes as follows:
4 = 4 speed (6 = 6 speed, etc)
L = longitudinal (T = transverse for FWD)
60 = series (60, 65, 80, etc)
E = electronic control
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
700r4 swap
