Old 04-16-2012, 03:56 PM   #76
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Project: Clean the Green Jimmy
Originally Posted by Gordonr1973 View Post
Looking great!!
thanks ....I think rims are due next
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-16-2012, 08:26 PM   #77
Factor
Factor's Avatar
lmao crap tire what dont they got lol , man that is mint my 86 was drove in hamiltion on for ever and when i got it being the 7th owner i had to chance evey darn panel and mount on the truck. it sucks / u barley need anything
Factor is offline   Reply With Quote
Old 04-16-2012, 11:42 PM   #78
motornut
78K & 79C Jimmys
motornut's Avatar
thats ok when i run outa stuff to do on one truck,I work on the other lol
John
Old 04-20-2012, 11:33 PM   #79
motornut
78K & 79C Jimmys
motornut's Avatar
http://www.youtube.com/user/TheMotornut?feature=mhee
gotta burn the oil ,before the paint lol
John
Old 04-24-2012, 01:09 AM   #80
motornut
78K & 79C Jimmys
motornut's Avatar
We got snow?
John
Old 05-17-2012, 12:20 PM   #81
motornut
78K & 79C Jimmys
motornut's Avatar
finally some real heat
off with the top,loaded up
John
Old 05-17-2012, 08:24 PM   #82
Looks good with out her lid!
Old 05-17-2012, 08:44 PM   #83
motornut
78K & 79C Jimmys
motornut's Avatar
thanks ,yup sure felt nice finally, to go topless lol
seems "the Boss" likes it too,lots of room to stretch out
John
Old 05-31-2012, 11:47 PM   #84
motornut
78K & 79C Jimmys
motornut's Avatar
workin on the cup holder
old paint kept peeling/cracking....
1 can so far and i still got a bit left
says chip resistant in a week....
gotta fix a couple of spots (lid ,center,top)but looks ok otherwise
I actually liked the "leather" look to the lid,before
John
Old 06-01-2012, 07:36 PM   #85
96twodoor
96twodoor's Avatar
looks great without the top
96twodoor is offline   Reply With Quote
Old 06-02-2012, 03:43 PM   #86
motornut
78K & 79C Jimmys
motornut's Avatar
thanks ,not gona happen this weekend rain and cold .......
John
Old 06-21-2012, 05:54 PM   #87
motornut
78K & 79C Jimmys
motornut's Avatar
got my cup holder/console done
John
Old 06-21-2012, 05:55 PM   #88
motornut
78K & 79C Jimmys
motornut's Avatar
valve covers too
John
Old 06-22-2012, 07:12 AM   #89
Nice work on the console & engine.
Old 06-22-2012, 07:43 AM   #90
motornut
78K & 79C Jimmys
motornut's Avatar
thanks it looks better and leaks less
it appears PO used white caulking on top of brown sealer
John
Old 07-13-2012, 04:33 PM   #91
made2drag
made2drag's Avatar
man i love it! i guess because it looks like mine only cleaner. is that the original color green. my glove box says seamist green and i wasnt sure if it was the actual color. have you found any touch up paint or spray in the exact color? i lowered mine 5 inches in the front and 4 inches in the back....zero money....oh, i see you put a newer dash on for a minute to try it. did everything line up? just wondering since i have to buy a dash piece that goes around the air vents and i may run into a newer dash
made2drag is offline   Reply With Quote
Old 07-13-2012, 04:36 PM   #92
made2drag
made2drag's Avatar
im planning on taking my carpet out and spraying tuff stuff on it and pressure washing it...is that how you did yours? your carpet looks amazing
Old 07-14-2012, 10:35 AM   #93
motornut
78K & 79C Jimmys
motornut's Avatar
I use spray nine doing the carpet, the pressure washer is awesome
It works on grease and coffee
Then some gain
I use the 89 sub dash in my 78,I use the 78 bezel no fit issues
But newer bezel and old pad leaves a bit of a gap
John
Old 07-15-2012, 05:57 PM   #94
made2drag
made2drag's Avatar
Then some gain
ok, cool..thanks!
Old 07-17-2012, 09:54 AM   #95
Corts60
Just here to tinker
Corts60's Avatar
Truck is looking great man!
Old 07-17-2012, 10:49 AM   #96
motornut
78K & 79C Jimmys
motornut's Avatar
thanks
I've picked up a newer style stock radio
(AM/FM/CASS/CB)for it,took the dash apart started to install it ...
after I was driving it on some rough roads and now smell gas
now it seems i got a hole in the sending unit
i can see vapours/spitting over the tank
could explain my bog lol
John
Old 07-17-2012, 12:02 PM   #97
Jonboy
Slots go on anything!
it may not be the sending uni, but rather the hoses going to it. They are probably the same age as the truck.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-17-2012, 12:10 PM   #98
motornut
78K & 79C Jimmys
motornut's Avatar
all the lines in rubber, i did first
the PO had a electric fuel pump between the reg one and the carb
sucked backwards from what i can tell(old lines in pic)
working my way to the back.....
watching gas vapours and the return spit ....
John
Old 07-22-2012, 02:11 PM   #99
motornut
78K & 79C Jimmys
motornut's Avatar
Got a used intake a few weeks back $50
went speaker shopping $80. got me
4-4X6@8ohms at least two for the front of this truck
2-4X10@10ohms for boxes if not the back
used taken out of pillars not dash baked
a reg mid 80s 4 speaker 2 post radio
and a CB antenna lip mount good for now, I'm not goin use the other setup
seems the PO used pop rivits to reuse the tank straps so they are on the gas repair list
John
Old 07-24-2012, 09:12 AM   #100
motornut
78K & 79C Jimmys
motornut's Avatar
got the radio/CB in
front speakers just fit,with clips removed
John
