Old 05-19-2012, 12:43 PM   #1
Spassmacher
What the heck is going on here?
So this is my first time assembling an engine, and I'm now getting to all the hoses and fittings and such. This is a picture of my engine as it was before I pulled it and rebuilt it. I'm trying to hunt down the fitting that is going from the top of my water pump to my thermostat housing. I'm not sure why that thermostat housing has an add-a-piece and goes down to the water pump, I'm pretty ignorant about all the passageways for coolant and fluids and such. So far I haven't been able to track down the fitting or the hose at any parts house. Anybody know what's going on here?
http://www.flickr.com/photos/72744831@N05/7227843970/
Spassmacher is offline   Reply With Quote
Old 05-20-2012, 11:21 PM   #2
Weasel Diesel
Re: What the heck is going on here?
It is a bypass used for fast warm up. Never seen it used on a chevy pickup smallblock though. Usually seen on marine engines. My Crusader marine engine had one on it and I did away with it when I rebuilt it and put it in my C10.
Weasel Diesel is offline   Reply With Quote
Old 05-21-2012, 01:10 AM   #3
Captainfab
60-66 Nut
I have seen a couple in pickups, but mostly in medium duty trucks. But it seems like the Corvette's may have had that also? Did you loose the original fitting? There are a couple on this page, but since they are stainless they are spendy.
http://www.summitracing.com/search/P...nless+fittings
You could just eliminate the riser under the thermostat housing, and plug the port in top of the water pump, and be just fine. That is how most engines are.
Old 05-21-2012, 08:29 AM   #4
truckdude239
truckdude239's Avatar
jus cap it off you dont need it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-21-2012, 09:21 AM   #5
butch86
butch86's Avatar
if i was you i would cap it off...... it really serves no purpose in your application.
thats just my vote and opinion on the deal.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf.
butch86 is offline   Reply With Quote
Old 05-21-2012, 09:57 AM   #6
Lee H
Lee H's Avatar
Captainfab is correct, medium duty trucks and cars of the 60s and very early 70s with SHP engines got the bypass. It was a safety precaution in case the thermostat stuck closed. Usually the bypass hose went into a nipple in the intake, not a spacer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-21-2012, 09:51 PM   #7
ray_mcavoy
Hi Spassmacher,
That looks like the stock bypass hose/adapter setup that was used on many 60's truck 327's. The pickup truck applications like yours used one bypass hose. While the medium duty truck applications used two hoses.
If you want to keep the stock bypass setup, the parts you need are still available. I recently went through tracking them down for the 327 we're getting ready to put in dad's 66.
The correct moulded rubber hose is Gates #20566. It's available from www.rockauto.com if you can't get it at a local auto parts store.
The 90 deg fitting that screws into the top of the water pump was a bit harder to locate. The original has a 1" hose barb and 1/2" NPT threads and is used in conjunction with a 3/4" to 1/2" reducer bushing in the water pump. The closest thing I could find were these fittings on ebay --> http://www.ebay.com/itm/5-FITTING-HO..._Parts&vxp=mtr They're nearly identical to the original except they have 3/4" pipe threads that go directly into the water pump (eliminating the need for the reducer bushing).
I've also heard that the bypass helps prevent localized hot spots inside the engine by allowing a small amount of coolant circulation while the engine is warming up with the thermostat still closed.
ray_mcavoy is offline   Reply With Quote
hose, housing, pump, thermostat, water
