Old 05-30-2012, 04:06 PM   #1
gmc1972
how to remove the rear window
hey guys I have a 72 gmc i need to remove the rear window and i dont want to break it is there any threads or can someone point me in the right direction thanks
gmc1972 is offline   Reply With Quote
Old 05-30-2012, 05:16 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: how to remove the rear window
to the board...
Does your rear window have the stainless trim around it? Quite a few of the guys and gals just cut the rubber around the glass and order a new Precison brand replacement rubber seal. If it has the trim you have to be careful which seal you get as there are two different ones.
I have taken them out without cutting the seal and re-used them but it is not the easiest thing to do.
LockDoc
Leon
Old 05-30-2012, 07:09 PM   #3
It's like changing a bicycle tire. You do it from the inside with two flat & thin prying tools...like screw drivers or whatever. I start in a bottom corner.
Old 05-31-2012, 12:10 AM   #4
farmall
farmall's Avatar
I just did it at the junkyard with a putty knife and the Bic pens I found in the cab. Like Spec stated, the inside is what you work on. The lower corner was a real pain, but once it was freed, it all came out nice. I was able to save the gasket as it was more pliable than mine. It went in my flat bed just fine as well. Now to find a windshield.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 05-31-2012, 06:01 PM   #5
mkmc69
mkmc69's Avatar
Can you remove a windsheild using the same method, and still save the gasket?
mkmc69 is offline   Reply With Quote
Old 05-31-2012, 06:06 PM   #6
69 gmc
69 gmc's Avatar
Is there an existing thread for this? A link maybe?
Calder
69 gmc is offline   Reply With Quote
Old 05-31-2012, 06:11 PM   #7
shawno72
C/10 junkie
shawno72's Avatar
subscribed
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 05-31-2012, 08:47 PM   #8
LockDoc
LockDoc's Avatar
I've used this method a few times. The rubber seal has to be fairly pliable and it has to be warm out. (or use a heat gun to warm up the rubber)
http://67-72chevytrucks.com/vboard/s...d.php?t=210843
LockDoc
Leon
Old 05-31-2012, 08:58 PM   #9
charlie diaz
charlie diaz's Avatar
LockDoc
This is a very true statement. I tried your method, and the rubber wasn't pliable at all. I ended up cracking the glass. It was already cracked anyways, I just didn't want to get glass everywhere.
As far as the black glass goes, it's really easy. I personally wouldn't worry about the seal because you should replace it anyways.
Just get a razor blade and cut the seal perpendicular to the window. Even though the seal is one piece, it will kind of tear out in layers. Once you get the outside layer off to where the window frame is exposed, you should be able to just give it a slight push and it will come right out.
charlie diaz is offline   Reply With Quote
Old 06-01-2012, 12:31 AM   #10
farmall
farmall's Avatar
Thanks for the windshield schooling Doc. I will try it.
Old 06-01-2012, 09:16 AM   #11
LockDoc
LockDoc's Avatar
No problem, hope it works for you. Anyone who tries it let us know if it works for you and if it doesn't, what the problem was... Thanks.
LockDoc
Leon
Old 06-01-2012, 11:02 AM   #12
Jos
SUbscribed
Jos is offline   Reply With Quote
Old 06-01-2012, 11:26 AM   #13
mr48chev
mr48chev's Avatar
I've found that if the rubber is stiff and hard you may as well just cut it and be done with it. I'll try Loc Doc's method when I change windshields in the 71 as the rubber is only two years old.
Old 06-01-2012, 11:59 AM   #14
elf w/capital T
i removed my rear window just two weeks ago, i took some time with removing the trim, started with the corners, took out the lh and rh trim and put some rope on the inside and little by little it popped out, UGH the rust plus old stiff rubber. not cool but hey its done.
elf w/capital T is offline   Reply With Quote
Old 06-04-2012, 11:25 AM   #15
gmc1972
thanks for all the tips im gonna try and remove mine tonight i was at two different shows over the weekend and only saw one gmc but a ton of chevys I cant wait to have mine done
Old 08-01-2021, 04:04 PM   #16
rgunlock
rgunlock's Avatar
Old thread, but it helped me out so thanks LockDoc!
On my 71, I used this method to remove both rear window and windshield without cutting the gaskets. My gaskets were pretty pliable (likely not original to the truck). I had an old Craftsman wet/dry vac I was tossing and cut the round power cord from it. Forced that behind the gasket from inside across the top and down the sides. You can actually force it far enough to go between the gasket and the top of the pinch weld lip, which holds the inside of the gasket away from the inside cab sheetmetal.
From there it was just a little persuasion with the flat of my hand to get an upper corner moving out. Might have to use your fingers right in the top corner of the gasket to help it start while pushing the glass with your other hand. After that, easy to get the rest of the top loose.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 08-01-2021, 08:41 PM   #17
LockDoc
LockDoc's Avatar
Wow! Glad it is still helping people. I have used that method on two or three other trucks since I posted it. I had one that had a lot of sealer used on it and it wouldn't work on it.
LockDoc
Leon
Old 08-01-2021, 09:38 PM   #18
67swb72klb
67swb72klb's Avatar
These nylon sticks help a lot when pulling glass
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-01-2021, 10:56 PM   #19
Richard
to the board...
LockDoc
Pretty sure the rear window trim is the same on all the years. Would be good to confirm that for people reading. While everyone may not have access. Some good pump type glass suction cups are great on the inside when you are working the gasket in. Especially true if you are doing it yourself.
Richard
Old 08-02-2021, 10:13 AM   #20
LockDoc
LockDoc's Avatar
My statement "two different ones" was referring to trim or no trim.... The rubber seals are different on the two, so you have to make sure you get the correct seal.
LockDoc
Leon
Old 08-03-2021, 07:42 PM   #21
slikside
slikside's Avatar
Sub'd. Good info!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 08-03-2021, 07:47 PM   #22
k29349
I don't think trying to save the gasket is worth the risk of cracking the glass. I would not miss the opportunity to install newer rubber anytime I had glass out. I keep cars forever though.
k29349 is offline   Reply With Quote
