Old 05-31-2012, 04:18 PM   #1
rcrahn
rcrahn's Avatar
14 bolt axle hose & fittings ?
I need some advice on the 14 bolt rear we've built (with disc brakes) for our project truck. We're now laying out all custom 3/16" brake lines. Having discs on the rear now we'll need a short flexible line to the caliper. Each side will transition to a hard line and meet at a T on the axle, from there another flex line will transistion from the axle to the frame. As seen in the far left of the first picture.
My request is to please see a picture of the fitting at the "T" junction which is sitting on that bracket on the axle.
I need to see exactly what fitting is being used. It appears there's a threaded hole for mounting whatever goes there. Any help is appreciated. Thanks.
rcrahn is offline   Reply With Quote
Old 05-31-2012, 10:21 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 14 bolt axle hose & fittings ?
The factory hard line runs under that tab. There is a bracket that is held on by your diff cover bolt, that the factory T fitting bolts to.
When I did mine I ran the rubber flex line from the caliper through the frame. I then ran a hard line from each side to the T fitting and bolted the T fitting under the cross member.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-31-2012, 11:00 PM   #3
rcrahn
rcrahn's Avatar
I understand what you are saying about the bracket on the diff cover. But to be certain it would be real nice to see any pics you have. It will be most helpful. Thanks for taking the time to respond!
Old 06-01-2012, 08:05 PM   #4
Mr. 250r
Mr. 250r's Avatar
Seems in one question you want a picture of the block and the next you want a picture of the bracket? Ill just get a picture of both
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 06-01-2012, 10:25 PM   #5
SunSoaked
SunSoaked's Avatar
Here's my 14FF in my M1008. You can see it all pretty good. Disregard the long "arm" on the bracket. I think it is only for the military application because it pivots and moves in relation the the spring compression and appears the change the brake bias with a heavy load.
SunSoaked is offline   Reply With Quote
Old 06-01-2012, 10:51 PM   #6
rcrahn
rcrahn's Avatar
WOW, that is some set-up! I appreciate you posting that!
I am aiming to keep it clean and functional. Been looking on-line for all the pics I can find (mostly on 4X4 sites) of the various ways lines are routed.
Old 06-03-2012, 04:30 PM   #7
Mr. 250r
Mr. 250r's Avatar
I had that long arm piece on my axle when i bought it from a regular one ton non-military although i threw it away
2003 1500 Silverado
Old 06-04-2012, 11:30 AM   #8
rcrahn
rcrahn's Avatar
I want to thank you guys for responding. This build has stretched out over time and I just could not recall the setup. After looking over your photos and digging up some old pics of this $100 14 bolt we started with I can tell what happened now. The original long arm bracket was shortened and simply welded directly to the axle tube. The junction or connector should sit there (it's bolted to it) and the hard brake lines will branch out directly from there. Because I'm running an airbag system I'll need a center hose made of the proper length. Hope that won't be an issue. Need to check with my local hydraulic hose shop for that.
