04-02-2012, 09:26 AM | #101 |
One day...
Re: Our "What are we going to do?" 66 Suburban Build
Hey looking good!!
04-02-2012, 01:32 PM | #102 | |
04-02-2012, 06:16 PM | #103 |
Thanks Scott, appreciate that.
Maybe not, I can get pretty attractive shipping rates...PM sent oem.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
04-02-2012, 06:29 PM | #104 |
new page needs a new pic to kick it off (one my son took)...
04-08-2012, 09:19 PM | #105 |
Had a local young striper lay down a bit of work on the burb...
04-09-2012, 02:08 AM | #106 |
That looks really good. Awesome addition to this cool burb!
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
04-10-2012, 09:08 PM | #107 |
Thanks carnut, it's fun to tinker around with different flavors on this burb. At some point we want to repaint it, but for the time being...
04-22-2012, 01:33 AM | #108 | |
04-22-2012, 01:39 AM | #109 |
These ralley's were originally from a 4x blazer and the front center caps were open...my son came up with this short-term solution
04-22-2012, 03:03 AM | #110 |
We're thinking about selling all the seats out of this and going a different direction
Check out the WIW section and help us make a decision...thanks!
04-22-2012, 06:43 PM | #111 |
Since you are not staying stock and you want to lower it a little, I would suggest taking the coil overload shocks out of the back and see where it settles. Then pull the front coils and cut 1/2 to 1 coil out of the front springs. This should settle the rear up to an inch and you can lower the front 1.5 to 2 inches with coil cutting. I use Vise Grips next to the cut and a wet rag inside the Vise Grips as a heat sink and cut the coil with a Skil saw with a metal cutting blade. That way you don't damage the spring tension buy using a torch. Since you are not staying stock I would put a set of disc brakes up front. 3.73's with the 700R4 in OD is a 2.62 highway gear. That engine will not be turning many rpms. A rebuilt 350 with a 305 HO cam, an HEI with a curve kit and a quadrajet, would be a nice engine for that truck if you want it to be a cruiser. A set of nice gas shocks on it and add a front sway bar with urethane bushings, it will ride and handle like a dream. What I love about these old trucks is the A arm bushings are lubable and last forever, not like the later rubber ones that wear out.
04-22-2012, 07:30 PM | #112 |
Hey man, get out of my head!
You're almost spot on with what we've been thinking!...almost. Talked to CPP Friday about their Grand Slam kit and adding front/rear sway bars, dropping the front 2.5" with spindles and bringing the rear down just enough to leave us with a bit of rake. The rear is sitting low (even with the overload shocks) because of the really tired stock springs...we're gonna have to do some fiquring to decide which front/rear springs to go with and get the stance right. Now, as far as the engine goes... I've got a nice little 468 being built down in Houston that will be pushing 500 hp on pump gas...will be picking it up mid-May
04-22-2012, 10:53 PM | #113 |
Cool, just make sure the springs are strong enough in the rear to handle the family and your picnic basket for cruises and car shows. I've seen guys put different weaker springs in the rear and have it banging off the bump stops with a couple rear seat passengers. For me I have to keep it limited to modifying stock suspension at most. My wife says I have dirt road fever and when we travel we hardly ever take one of the cars any more. I always want to know whats down that dirt road. I guess you can take the boy out of the country, but not the country out of the boy. I was born in Northwest Ohio and when I go back it still feels like home to me. 15 minutes out of any decent sized city in Northwest Ohio and your out in the country, I love that!
04-23-2012, 01:15 AM | #114 |
60-66 Nut
Yep those tires look good.
When choosing your front springs and spindles, just remember that big block is going to drop the front a little more.
04-23-2012, 01:27 AM | #115 |
One of the reasons I'm talking with CPP is their "heavy-duty" rear springs...I'd actually like to increase the rear spring rate for exactly the reasons you've stated.
04-23-2012, 01:33 AM | #116 |
Planning on it...
06-06-2012, 04:27 AM | #117 |
No updated for 6 weeks, what's up??
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
06-07-2012, 09:53 PM | #118 |
Just been enjoying it while we gather up parts. We picked up a mildly built long block BBC and have been dressing it out...just finished the alt mount, working on the ps and ac compressor mounts next. We also swapped out the 700R4 for a built 400...should handle the BBC better.
06-08-2012, 01:38 AM | #119 |
chevy only
oh boy!
CHEVY ONLY... Nothin Else ! |
06-08-2012, 05:11 PM | #120 |
One day...
06-09-2012, 11:33 AM | #121 |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
06-10-2012, 01:45 AM | #122 |
Junk Yartist
big block everything huh?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
06-10-2012, 06:46 PM | #123 |
Oh yea, "no replacement for displacement" holds true around this household!
I just dig big blocks, always have, always will! This one is running forged 10:1 domes in a gen VI block w/ 049 heads, bit of a lumpy cam and a Holley 750 on a air gap. Not alot more done this weekend, but did get the ps mount pretty much done...just got to drop a tensioner on it. Just keep chipping away at it...
06-11-2012, 12:09 AM | #124 |
I've loved subs ever since before I could say it called them Burbans when I was about 3 or four. This one makes me love them even more. Super nice rig hope you guys really enjoy that thing.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
06-12-2012, 02:49 PM | #125 |
