Old 06-17-2012, 11:05 PM   #301
Bowtie468
Bowtie468's Avatar
Re: Bowtie468's Extreme '68 BuildPage
Originally Posted by darkhorse970 View Post
He's an outstanding paint and body man, but an even better man and friend! (I know that you know this Chris, but I just felt like he deserves some more recognition!!) Your truck will be on magazine covers when you are done!!
More pics, more pics....
Thats for sure Keith ! Well said ! I'd be stoked to see it in a magazine someday. Here's your pic request. Showed up at the shop on Friday. !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 06-18-2012, 12:00 PM   #302
Str8-6-68
Str8-6-68's Avatar
Subscribed! This is turning out to be one beautiful 68, love the fine detail applied to this build. Great job Chris!
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 06-18-2012, 12:14 PM   #303
Bennett68C10
Bennett68C10's Avatar
Chris is that a one-piece or two-piece driveshaft.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-18-2012, 12:25 PM   #304
scotts72heavyhalf
scotts72heavyhalf's Avatar
Thats one beautiful 68! Very nice work and attention to detail
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 06-18-2012, 04:00 PM   #305
Bowtie468
Bowtie468's Avatar
It's a one piece shaft Keith ! 3 1/2" dia . My original plans were to go 4" alum. But had clearance issues when aired out. Denny's said that this 3 1/2 will handle 750 HP. I figured I'm good .... For the time being !!!!
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-19-2012, 11:18 PM   #306
Bowtie468
Bowtie468's Avatar
Hood and cowl are going to the paint shop in the morning !
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-20-2012, 08:17 AM   #307
Bennett68C10
What U-Joints are you running, 1330 or 1350. The only reason I am asking is because I'm looking to do a similar setup. I have been checking out their website trying figure out what I will need. My problem is I don't know my ride height yet, have to get the bed back on to figure it out. Are you still using the stock trailing arm crossmember or did you change it?
Keith
66 Suburban
IG: bennett68c10
Old 06-20-2012, 08:46 AM   #308
67cheby
67cheby
67cheby's Avatar
I have never told anyone this before but.....that is the best looking shaft I have ever seen !
67cheby is offline   Reply With Quote
Old 06-20-2012, 09:49 AM   #309
99-LS1-SS
99-LS1-SS's Avatar
I have to say that I agree with you.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 06-20-2012, 10:34 AM   #310
Bennett68C10
Keith
66 Suburban
IG: bennett68c10
Old 06-20-2012, 11:16 AM   #311
superflysteiny
superflysteiny's Avatar
What is the hp rating on the big block. Only reason I ask is I am trying to figure out what size shaft I need to run with my engine.
superflysteiny is offline   Reply With Quote
Old 06-20-2012, 08:47 PM   #312
Bowtie468
Bowtie468's Avatar
u joints are 1330 . Also I'm running a Porterbuilt crossmember
lol !!! Well just for the record, I didn't ask Dennys for a nice shaft , this is just what they sent . It was out of my hands !!
this bbc dyno'd at 540. When I couldnt get a 4" alum to clear, I called and told them I wanted their 3 1/2" HD steel shaft . They informed me that the 3 1/2" alum would withstand to same power levels as their steel HD shaft, which is rated up to 750 hp. So I went with the prettier one ! Lol
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-27-2012, 11:50 PM   #313
Bowtie468
Bowtie468's Avatar
Still plugging away at it . No new pics but the last week consisted of dropping the trans and installing the converter along with a new pan , removed trailing arm crossmember and powdercoated. Reinstalled and bolted up new driveshaft. Headlight assemblies, park lamps are complete . Front bumper is on the way .
I've made a tempory change on the air ride setup for the time being . I'll just control it for now with paddle valves , the Accuair setup will still happen, I'm just trying to get the truck done for CTC in October without bankrupting myself !
I'm looking for a way to mount the paddle valves in a cool way instead of just bolting the panel under the dash . What ideas do you guys have for this ?
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-28-2012, 06:44 AM   #314
c10327
c10327's Avatar
very nice !! i have a 70 c10 I'm getting close to paint,an it's going to be black as well , question is what is the blackest black you can buy in a base coat system ?
c10327 is offline   Reply With Quote
Old 06-28-2012, 10:57 AM   #315
Str8-6-68
Str8-6-68's Avatar
If your not tweaking your valves too much maybe relocate your valve bank to your glove box for the time being??
Old 06-28-2012, 12:14 PM   #316
gringoloco
A guy with a truck
gringoloco's Avatar
It was, I think, n2billet's semi-famous 'Lucy' that had the contoured 'box' centered at the front of the bench seat. Can't seem to find pics of it now, but it basically sat where your hand would naturally fall, just behind where a floor shifter would be, attached to the seat frame, but mostly concealed.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-28-2012, 10:31 PM   #317
Bowtie468
Bowtie468's Avatar
That did cross my mind, unfortunately it's slam full of electronics ! I've got one little area left , and it's reserved for the (electric) fan controller .
DuPont has a Super Jet Black which is avail in a factory pack. When you get into the jet black, they all have a purplish hue to them. My preference is a clean black with no purple or brown tint to it . Check it out , it may be to your liking !
I'll check on that gringo ! That looks like the direction ill take with this . For some reason I was thinking it was Kens (N2TRUX) truck that had it ! Thanks !
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 06-29-2012, 01:33 AM   #318
Valhalla
Valhalla's Avatar
You got some skillz man. That truck is looking amazing.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 06-29-2012, 08:38 AM   #319
Lolyin58
Lolyin58's Avatar
Very nice build. Great work!
Lolyin58 is offline   Reply With Quote
Old 06-29-2012, 09:51 AM   #320
gringoloco
A guy with a truck
gringoloco's Avatar
Me too. In my memory it was dark red, like his interior. Maybe before he put the digital controller in the ash tray?
Edit- found it:
More pics here: http://67-72chevytrucks.com/vboard/s...light=switches
I've also seen guys mount paddles to the seat frame, but not sure I like the look...
-Chris
Old 07-03-2012, 09:07 PM   #321
Bowtie468
Bowtie468's Avatar
Thanks gringo , I just noticed your last edit . I'm still racking my brain on this thing and really don't want to spend a bunch of fab and paint time on something temporary . I studied it some more this evening, and realized there is no visible frame on the Teas seat , it's all covered in leather. I think I'll try something where the switch panel just slides out from under the seat on the drivers side .
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 08-07-2012, 10:24 PM   #322
Bowtie468
Bowtie468's Avatar
Some more progress to speak of ! Hood and cowl came back from paint shop and were installed this past weekend. Air ride system is complete. I've still got to replace the door seals so we can do a final panel alignment. Who's got seals that are close to the same thickness as the GM seals.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 08-07-2012, 10:27 PM   #323
67cheby
67cheby
67cheby's Avatar
Gorgeous !
Old 08-07-2012, 10:29 PM   #324
Bennett68C10
Truck looks great, glad to see your making some progress
Keith
66 Suburban
IG: bennett68c10
Old 08-07-2012, 10:32 PM   #325
killer71
killer71's Avatar
Who's layin down your paint?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
