Old 06-21-2012, 12:06 PM   #1
chevy72blu
chevy72blu's Avatar
Installing a Boyd's tank. Do I have to remove the bed?
I am jumping back into my project and I plan on installing a Boyd's in bed fill EFI tank. This is probably a silly question as it would make life a lot easier to install it with the bed removed, but I work alone in my shop and I may not have much help besides the wife.
Is it possible to install the tank with the bed still on? I would plumb and wire it before setting it in, use a marker taped to the filler neck to mark a hole, and drill from the bottom side for the opening.
Do-able?
chevy72blu is offline   Reply With Quote
Old 06-21-2012, 12:33 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Installing a Boyd's tank. Do I have to remove the bed?
Possible, I suppose. But, it would be a LOT easier with the bed off. Holes to drill; lines to run and secure plus wiring......just sayin'.
Member Nr. 2770
Old 06-21-2012, 07:15 PM   #3
mixermike
mixermike's Avatar
I installed mine with the bed on. Not that bad
mixermike is offline   Reply With Quote
Old 06-21-2012, 07:20 PM   #4
RaceAGMC
RaceAGMC's Avatar
Not trying to thread jack but are you guys mounting the tank to the bottom of the frame? I had to relocate the rear most cross member to get my Boyd tank to fit.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 06-21-2012, 09:23 PM   #5
bubba353z
bubba353z's Avatar
Yes - that way if it ever needs to come out, you don't have to pull the bed. I cut out the cross member too - only way it will fit.
bubba353z is offline   Reply With Quote
Old 06-22-2012, 08:17 PM   #6
chevy72blu
chevy72blu's Avatar
Can anyone post pics of where they had to cut/move the x-member? I surely wont be spending $700+ on a tank if I need to make the same modifications that will be needed with a junk yard pull out..
Thanks for the help
Old 06-22-2012, 10:39 PM   #7
bubba353z
bubba353z's Avatar
I had to cut out the small crossmember above where the spare was - the big crossmembers at the end of the frame and where the panhard bar meets the frame are OK. There's not a huge amount of clearance for the tank, but it fits.
Old 06-23-2012, 12:36 AM   #8
CigarMan
If I were to do this alone I would un bolt bed and block it with wood to elevate up maybe 12 inches or so. That would be easy enough for one man to do.
CigarMan is offline   Reply With Quote
