Old 06-22-2012, 04:06 AM   #1
GMC70c20
LQ4 crank and block qeustions
I am about to order the parts to assemble my lq4 and I thought about installing new bearings seens how I was gonna check all the bearings anyway and put in new arp rod and main bolts. I've heard good things about the cleavite h bearings but I'm not sure those would be the ones to get. The motor is a stock lq4 short block, l92 heads, victor jr, msd ls6 controller, muthat thumpr cam, kooks 1-7/8 headers, mildon oil pump, manley timing set, roller truion conversion, 10.2:1,and a quick fuel 750 race-q carb. What kind of bearing work well with a factory bottom end? also what kind of power would I have to make before I should worry about the rotating assembly?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 06-24-2012, 04:50 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: LQ4 crank and block qeustions
the stock bottom ends are good for 600hp....I'd def go with the arp bolts, and clevite bearings....sounds like you're building a decent motor there...
mooseknuckles is offline   Reply With Quote
