Old 06-17-2012, 05:42 PM   #126
Tinkermc
Re: Project "Just an Old Truck"
truck lookin real goooood, very nice work, hope you leave the paint alone it looks so good now
Tinkermc is offline   Reply With Quote
Old 06-20-2012, 09:31 PM   #127
gringoloco
A guy with a truck
gringoloco's Avatar
I like this truck! I need to find a reason to visit Eglin again, love that place...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-22-2012, 10:56 PM   #128
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Worked on the old gal for a couple of hours tonight, made some progress. Fuel lines are built and cushion clamped to the frame. Put the rear bumper on for a test fit. Tomorrow I will work on front brake lines, and if that goes well I will move on to the wiring, (computer and gauges).
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 06-25-2012, 06:59 PM   #129
C10_ustacould
Updates from the weekend... Finished the hard lines for the brakes, just have to build mounts for the steel to rubber connection for the fronts. Connected the brake pedal push rod to the CPP booster and master cylinder. Also mounted the brake pedal pad to match my throttle pedal. Installed the Lokar throttle cable. Had to make a couple of washers for the cable bracket on the manifold, see picture.
Thanks are due for n2billet and 68 short step for imparting some C10 wisdom, thanks guys you've helped keep my project moving!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 11:05 AM   #130
tsali39
tsali39's Avatar
Originally Posted by BucksSS View Post
Put the bed on today...
Ok, I love those wheels and caps. They look like 96-02 Astro caps. What holds them on? Are those 15" rally wheels? I would love to have a set like that!
Eddie
tsali39 is offline   Reply With Quote
Old 06-26-2012, 12:58 PM   #131
Hart_Rod
Hart_Rod's Avatar
Nice progress! Sorry I missed the get together (uh hmmm where are the pics??!!!) the gauges look great! Have you hooked them up? Where did you get them and how much $$$$??. OBTW, the box was the axles, thanks.
Hart_Rod is offline   Reply With Quote
Old 06-26-2012, 01:15 PM   #132
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress!
Old 06-26-2012, 04:23 PM   #133
C10_ustacould
Really didn't have a get together. Keith had plans for Wednesday (his grand daughters birthday) and most folks didn't really care to meet in the middle of the week. He came by the house Tuesday night to check out the truck and I got a great deal of 67-72 C10 info.
I haven't started the gauges yet, need to finish the brakes first. After that I am going to do the engine harness and gauges. They are from Classic Instruments, I got them off of eBay for $809 shipped. You tell them what eng/trans you have and they include the correct senders etc.
Thank you for fronting me the axles, glad the replacements finally showed. Those guys sure are getting slow with their shipping...
Hey are you going to Cruisin' the Coast this year?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 04:34 PM   #134
C10_ustacould
You are correct they are 96-02 Astro caps on 15x7 front and 15x8 rear rallies. I used factory S10/Astro lug nuts and the black covers hold the cap on. I really like them and I think they will look better when I add deep trim rings.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 05:51 PM   #135
Hart_Rod
Hart_Rod's Avatar
Thanks you for fronting me the axles, glad the replacements finally showed. Those guys sure are getting slow with their shipping...
Any time I can help, you know I will. I plan on going to CTC. I would like to camp out instead of staying in a hotel as the prices for the rooms on the strip are getting rediculous (almost $300 a night.....). Still working on that game plan. Suggestions???
Old 06-26-2012, 08:53 PM   #136
C10_ustacould
Still contemplating how I am going to mount the front brake steel line to rubber hose connection to my cross-member. I am using the 73-87 cross-member so the factory mounts aren't there. In the meantime, and after getting some great info from 68 Short Step, I built my power steering lines! Only took about an hour. It is awesome to be able to eliminate the hours, days, or weeks searching for the correct part numbers, and buying the right parts the first time saves money too! That is just one of the outstanding things about this site...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 09:46 PM   #137
C10_ustacould
I am looking at Hotel/Casinos, my wife is planning to come and she won't do camping.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 10:11 PM   #138
lolife99
67-72 parts collector,…
lolife99's Avatar
Run your brake lines thru the frame like they did on the 73-87 trucks.
Otherwise you will have to add a tab to the crossmember.
Keith
Convert to disc brakes.
Old 06-26-2012, 10:20 PM   #139
C10_ustacould
Well, I already built the hard lines for the other way... There is a hole in the 68 frame forward of the cross-member, can I use that as the steel/rubber interconnect point if I choose to go the other route?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 10:26 PM   #140
lolife99
lolife99's Avatar
Sure.
You can use the 73-87 rubber brake hoses also since they are so much longer and have a "bulkhead" type fitting made on the end of the hose.
Keith
Old 06-26-2012, 10:51 PM   #141
C10_ustacould
Checked and one of the local parts stores has hoses in stock. I'll get a set and look into swapping the hard line to the front of the cross-member. Thanks for the new angle!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 06-26-2012, 10:57 PM   #142
gringoloco
A guy with a truck
gringoloco's Avatar
That's how they're run on my '70-- works well, and there's a tab on the '73-up lines to attach to the upper control arm as well to keep 'em from floppin' around...
-Chris
Old 06-27-2012, 07:33 PM   #143
C10_ustacould
Any chance you can throw me a pic of your set up? I am curious how the lines route from the master cylinder to where they go through the frame.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-03-2012, 08:29 PM   #144
C10_ustacould
A couple more things have been marked off the list... well one is are a redo. Transmission cooler is mounted and lines are built. I redid the front brake hard lines. and started to layout the engine wiring harness...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-05-2012, 09:08 PM   #145
C10_ustacould
Here are my latest trials to overcome:
1.) 73-87 style rubber brake hoses hit the upper ball joint nut... searching for an alternative.
2.) Starter bolts for a 5.3L are non-existent except for online, dealer couldn't even get them. And if he did they would be $20 each... EACH! So, I ordered 2 of them from Rock Auto for $7.84 total... SHIPPED. Not sure what the deal is with that one.
3.) Wiring... nothing else to say, the one word says it all!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-05-2012, 10:00 PM   #146
gringoloco
A guy with a truck
gringoloco's Avatar
Sorry I missed your question- mine are routed 73-87 style- prop valve on front crossmember. Yours looks like it turned out nicely. I've had luck just bending the brake lines to clear the nut...
-Chris
Old 07-05-2012, 10:17 PM   #147
C10_ustacould
I guess I can give that a try... the hoses aren't doing me any good if I don't. I worry about weakening them and risking a rupture.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-05-2012, 10:50 PM   #148
lolife99
lolife99's Avatar
I guess I can give that a try... the hoses aren't doing me any good if I don't. I worry about weakening them a risking a rupture.
Tweak the hose at the ball joint nut.
Every set of drop spindles I have ever installed required it.
It's normal.
Keith
Old 07-05-2012, 10:55 PM   #149
C10_ustacould
It's normal.
What would I do without you guys! Oh yea, I'd sit around counting all my money cause I wouldn't be spending any on truck parts! lol
Seriously, thanks for all of the help you all provide. It is much appreciated!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-06-2012, 12:33 AM   #150
67c10rustbuket
67c10rustbuket's Avatar
Great job on the build and lots of good info too. Love the engine and wish I had one of those
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
