Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 06-30-2012, 11:09 AM   #1
68panelman
68panelman's Avatar
Brake fluid
Just about to finish the brakes on the '42, Wondering if I should go Dot5 or Dot3 for brake fluid. Is dot5 better for a vehicle that is not used alot? Is it safe on the rubber parts in wheel cylinders?
68panelman is offline   Reply With Quote
Old 06-30-2012, 03:58 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Brake fluid
dont i say Dont use dot 5 ,use the dot 3 or 4 ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-30-2012, 04:00 PM   #3
fastwillie 696969
~Rest In Peace~
Re: Brake fluid
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure. DOT 5 brake fluid is not compatible with anti-lock brake systems. DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.
[edit] Boiling points
Minimal boiling points for these specifications are as follows (wet boiling point defined as 3.7% water by volume):
Boiling point ranges [2]
Dry boiling point
Wet boiling point
DOT 3
205 °C (401 °F)
140 °C (284 °F)
DOT 4
230 °C (446 °F)
155 °C (311 °F)
DOT 5
260 °C (500 °F)
180 °C (356 °F)
DOT 5.1
270 °C (518 °F)
190 °C (374 °F)
Old 06-30-2012, 07:02 PM   #4
68panelman
68panelman's Avatar
Re: Brake fluid
Thanks Willie, Dot 3 it is!!
