Old 07-07-2012, 09:03 PM   #151
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: Post Your Engine Bay Pics!!!!!!
Originally Posted by 68Stepbed View Post
I'll make another post since mine has changed. Mine now has a carbed LS1 engine.
That is stunning, Matt. Do you have a color code for the silver or any details you could share? Silver is silver, sometimes, but that looks like the most perfect silver I've ever seen.
BruthaMan is offline   Reply With Quote
Old 07-07-2012, 10:22 PM   #152
waybad
waybad's Avatar
very nice!!
waybad is offline   Reply With Quote
Old 07-07-2012, 11:23 PM   #153
68Stepbed
68Stepbed's Avatar
It's actually spray can. It's DupliColor Cast Coat Aluminum engine paint. I was gonna stick with the gray/blue theme my small block had, but it never looked quite right. The engine is all aluminum, and I wanted it to stay looking good, so painting it aluminum color keeps it that way.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-09-2012, 10:36 PM   #154
Crosshair Cowboy
Crosshair Cowboy's Avatar
Subscribed
1969 K20 4x4
1989 V1500 Burb
Crosshair Cowboy is offline   Reply With Quote
Old 07-10-2012, 02:19 AM   #155
Daaaanz67
Mine just finishing my ls conversion
Daaaanz67 is offline   Reply With Quote
Old 07-10-2012, 08:44 AM   #156
67cheby
67cheby
67cheby's Avatar
I like it with all of the orange peaking out !
67cheby is offline   Reply With Quote
Old 07-10-2012, 09:13 AM   #157
Tmwoodall
What is your total cost on the swap if you don't mind my asking? If my 350 ever craps out, I'll be really tempted to drop a Vortec roller in instead of building another old school SB.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 07-10-2012, 11:32 AM   #158
Daaaanz67
There is a whole stack of receipts on the dash and some in a drawer at home. I haven't even begun to add all this up. There has been a lot of work done on this truck and I may have went over board on some things but wanted to do it right the first time and not go back and spend more money nothing was half a*****s on this conversion.
Old 07-10-2012, 11:34 AM   #159
Daaaanz67
Thanks 67 cheby
Old 07-10-2012, 12:56 PM   #160
68Stepbed
68Stepbed's Avatar
How about an action pic?
Matt
Old 07-10-2012, 01:35 PM   #161
Daaaanz67
Just got it out of the exhaust shop getting ready to plumb all liquid lines. The truck does start and run once done I'll try to post a video. This thing runs awesome and sooooo smooth when it's idling.
Old 07-10-2012, 01:42 PM   #162
OJ1988
Just a car guy
OJ1988's Avatar
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-24-2012, 04:05 AM   #163
bopper_702
bopper_702's Avatar
Originally Posted by bigsnookmaster View Post
My 68:
this bay looks great.. very nice
bopper_702 is offline   Reply With Quote
Old 10-24-2012, 01:39 PM   #164
Graham57a
Graham57a's Avatar
Not quite done but it's getting there. Probably gonna end up doin an LS or big block swap somewhere down the road. This is just a plain ole 350, double hump heads, aluminum intake, mild cam, holley carb. Before, after
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 10-24-2012, 02:47 PM   #165
c10srule
c10srule's Avatar
heres mine
c10srule is offline   Reply With Quote
Old 10-24-2012, 02:58 PM   #166
c10srule
c10srule's Avatar
better pic of mine and one of my wifes
Old 10-24-2012, 05:21 PM   #167
jetdrive4u
jetdrive4u's Avatar
1968 SWB - Project JA
1969 Camaro RS/SS 396 Conv
jetdrive4u is offline   Reply With Quote
Old 10-24-2012, 06:56 PM   #168
AusTx68
AusTx68's Avatar
Does this LS motor use coil packs? I don't know a lot about LS motors but I thought they all used them. I don't seem them in the pic.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 10-24-2012, 08:47 PM   #169
Daaaanz67
If you look close you can see them mounted where the dist. Would be only know this by reading his build thread awesome truck
Old 10-24-2012, 09:50 PM   #170
68Stepbed
68Stepbed's Avatar
Yes, it has coil packs. I relocated them to the back of the engine just behind the intake. With everything else, it kinda just looks like a weird distributor back there.
Here's a couple better and more recent pics.
Engine swap thread is here--> http://67-72chevytrucks.com/vboard/s...d.php?t=506692
GM makes a distributor conversion kit for LSx engines, though. It mounts in place of the front cover, and has a piece that bolts to the front of the cam with a dist. drive gear and a fuel pump lobe to be able to run a mechanical fuel pump. It uses a SBF dist.
Here's a link to a build with a front drive dist. conversion, and also with a front accessory system that will be similar to what I will eventually run. http://ls1tech.com/forums/carbureted...71-camaro.html
Matt
Old 10-24-2012, 10:00 PM   #171
Hubscrub
Cruzin
Hubscrub's Avatar
^ wow at that rad hose, i'm not a big ls fan there usually not to pretty, but yours is nice with that carb sittin atop.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-25-2012, 07:48 AM   #172
68Stepbed
68Stepbed's Avatar
Yeah, the rad hose is gonna get changed. I think I'm gonna have my buddy at a machine shop make a threaded insert to go into the top of the water pump, then have custom metal tubing made for a custom fit.
Matt
Old 10-25-2012, 03:08 PM   #173
c10srule
c10srule's Avatar
best looking ls ive seen, nice job,
Old 10-25-2012, 04:43 PM   #174
data89
What!!! no inline 6's?
data89 is offline   Reply With Quote
Old 10-25-2012, 10:02 PM   #175
Hubscrub
Cruzin
Hubscrub's Avatar
those great motors have a special 6 only threads
67-72chevytrucks.com/vboard/showthread.php?t=258488&page
67-72chevytrucks.com/vboard/showthread.php?t=471078
Proverbs 3:5,6
