Old 05-06-2010, 12:36 PM   #1
djw32
LS ecu mounting in 67-72?
Hey guys,
Where did you mount your ecu? Please post pics if you have them.
David
djw32 is offline   Reply With Quote
Old 05-06-2010, 03:20 PM   #2
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Re: LS ecu mounting in 67-72?
Passenger side kick panel and built kick panel covers for it. Will post pics when I get home.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 05-07-2010, 02:00 AM   #3
Sicmaro
Always wrenching!!
Sicmaro's Avatar
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 05-07-2010, 06:51 AM   #4
72RK
72RK's Avatar
Under the seat...
72RK is offline   Reply With Quote
Old 07-08-2012, 01:56 PM   #5
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Lets bump this up to find out if there are any new ideas out there... include some pictures if possible.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-08-2012, 02:29 PM   #6
farmtrucks
farmtrucks's Avatar
I layed mine flat, right behind the speedo - used a small bungee cord under it and the steering column harness - it's hidden and accessable - I put some dynamat around edges to cushion it from the brake pedal bracket. My cab is crowded a/c vents/hose, radio, vintage air box.
farmtrucks is offline   Reply With Quote
Old 07-08-2012, 02:43 PM   #7
sbc10guy
sbc10guy's Avatar
Mines mounted under the dash behind the radio area. Its out of sight unless your looking for it.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 07-08-2012, 05:00 PM   #8
RocketKing
RocketKing's Avatar
I could not get mine to reach to under the glove box. So I did this.
no pics after I painted it black and mounted it but it is easy to get to and looks good.
Rex
RocketKing is offline   Reply With Quote
Old 07-08-2012, 05:31 PM   #9
68 short step
on the firewall, behind the intake.... hidden, yet easy accessible...
here is a write up on it
http://67-72chevytrucks.com/vboard/s...d.php?t=375461
68 short step is offline   Reply With Quote
Old 07-08-2012, 05:59 PM   #10
C10_ustacould
That is sweet, but the engine is in my truck so I can't get to that area to drill holes or weld the tabs on. I do like the idea of using the factory box. I think I am going to mount mine to the backside of the radiator support on the drivers side.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-09-2012, 11:16 PM   #11
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Buck, I have one of the factory mounts... It was in my toolbox and I forgot about it.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 07-10-2012, 01:55 AM   #12
Daaaanz67
Here's mine
Daaaanz67 is offline   Reply With Quote
Old 07-10-2012, 11:54 AM   #13
Hart_Rod
Hart_Rod's Avatar
nice ^ !
Hart_Rod is offline   Reply With Quote
Old 07-10-2012, 07:21 PM   #14
dkauffman05
dkauffman05's Avatar
Mine is inside the ammo box
dkauffman05 is offline   Reply With Quote
Old 03-27-2014, 09:17 AM   #15
dman1982
dman1982's Avatar
i was thinking a very similar idea....just when i thought i was being original!!!!
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-27-2014, 09:33 AM   #16
Matt Cramer
Mounted to the A/C evaporator housing with riv-nuts. It's not a stock ECU and is substantially lighter; I'm not sure you could get away with that on a stock ECU. Will try to get pictures up soon.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 03-27-2014, 10:59 AM   #17
JJH Jimmy
JJH Jimmy's Avatar
I mounted mine under the dash on the drivers side. I built a bracket and welded it to the brake support.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-03-2016, 04:27 PM   #18
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
I figured this was worth bumping up even though its very old. Good pics, great ideas. Any others out there?
Im thinking of mounting my pcm and TAC module on the frame rail.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 02-03-2016, 04:42 PM   #19
Wasted Income
Boosted Member
Wasted Income's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=695871
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-03-2016, 06:54 PM   #20
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: LS ecu mounting in 67-72?
Mine is in the glove box. I mounted the little LED in the under dash hole in the truck for the check engine light. It was already there. At some point I'll move it to the dash it self.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-03-2016, 07:00 PM   #21
Bagd72Chevy
C10 Collector
I have an older vintage air setup and it takes all the room under most of the dash. Gonna have to look at it a little harder.
///Ryan
1971 Blazer - Rusty
Old 02-03-2016, 07:25 PM   #22
lutronjim
Put Vintage Air in 70 C10 which did away with blower motor. Mounted to firewall where motor was.
lutronjim is offline   Reply With Quote
Old 02-03-2016, 08:03 PM   #23
boraxman
Keepin an eye out
boraxman's Avatar
Mines mounted to the driver side inner fender on a fabbed bracket but this tread now has me thinking about relocating it/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-03-2016, 08:15 PM   #24
aod92
aod92's Avatar
Mine is also I the glove box.
aod92 is offline   Reply With Quote
Old 02-04-2016, 10:54 AM   #25
67 chevelle
67 chevelle's Avatar
I have my e38 ,for a gen 4 motor ,mounted on the brace between the front drivers fender and core suport , looks as if its made for it , relays below mounted to inter fender
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
